Question about Microsoft Windows Vista Ultimate Edition
I have brought a new usb bluetooth of enter company v2.0 its asking for a drivers what to do..i searched the internet it display no driver found
    Sergeant:
    Champion:
  • 251 Answers
Vista should reconize it
Posted on Nov 27, 2008
Foxconn bluetooth plus edr
Seems that your bluetooth edr is a usb device, it might be made by third company: I found this text
Your Device Info Foxconn Bluetooth 2.0 plus EDR Hardware ID USB\VID_0A5C&PID_2101&REV_0100
Compatible IDs:
USB\CLASS_E0&SUBCLASS_01&PROT_01
USB\CLASS_E0 Version Driver Found Device Type btm Driver Version OS Support 2K,XP,2K3,VISTA,WIN7/32bits
XP,VISTA,WIN7/64bits Driver Date Manufacturer Motorola, Inc. Foxconn Bluetooth 2 0 plus EDR Driver Download for 2K XP 2K3 VISTA WIN7...
Mar 23, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Bluetooth usb dongle driver
Hi, You must have the model number of your device in order to obtain the correct driver. If when you plug it in and a window comes up offering to search the internet for a driver select that option. If after and the search proves unsuccessful, updating it from the Device Manager will also fail. It's possible that the computer will recognize the device and not give you the window explain above. In that case try to locate the device in the Device Manager. The device will be flagged. Right click and update driver. Good Luck
Feb 10, 2014 | Computers & Internet
Redfox wizbook 1020 wifi driver
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
Click on the "Start" menu and selecting "Control Panel.
"Click on the icon that reads "hardware and Sound."
Then, select the tab that reads "Bluetooth Devices."
Click on the "Add" button.
This will put your computer in "Search Mode."
This means that it will search for any compatible Bluetooth devices in the area.
Put your Bluetooth device in "Discovery Mode."
This can be done by pressing and holding the button on the side of the device.
This will cause the device to send out a signal that will be received by the laptop computer. Select your device from the list of found devices on your laptop.
Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then.
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled".
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
http://top.windows9download.net/list/redfox-wizbook-n1020i-driver-wifi.html
Redfox drivers
If still no joy with the driver
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Sep 05, 2013 | Computers & Internet
About tool bluetooth acer aspire 4315
What about the bluetooth tool? You can always try downloading and reinstalling the bluetooth driver.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Bluetooth drivers.You can also purchase a USB Bluetooth Adapter that plugs into one of the usb ports of the computer. It comes with drivers and software. Get it from Tiger Direct at:
http://www.tigerdirect.com
When the site comes up type:USB Bluetooth Adapter in the white search box at the top of the page and click GO. Sort the returned results by Price Low to High.
May 29, 2012 | Acer Aspire 5500 5570-2609 Laptop
IVE KOST THE DISK WHAT CAME WITH WITH THE BLUETOOTH USB STICK CAN YOU HELP
Just plug in the stick your your computer, then it will automatically search for the driver. If not found better to connect your pc in the internet, then search the driver.
Jul 02, 2011 | Computers & Internet
Na virus un asus 701 laptop ko. pina format ko pero ayaw gumana un LAN at un wireless internet connections
HI...
MAG-DOWNLOAD KA NG DRIVER SA LAPTOP MO. IT'S THE ONLY WAY SEARCH MO "ASUS 701 DRIVER DOWNLOAD" SA SEARCH ENGINES...
GOODLUCK!!!
Jan 04, 2010 | ASUS Eee PC 701 Notebook
I have to install pc camera driverless high speed USB2.0 , but i need the driver.
Do a Internet search by entering your model number on your favorite search engine.
Dec 12, 2009 | Adapters.com BT-0333 Bluetooth USB Adapter...
Connecting the printer to a bluetooth note book
Installing the Printer in Windows Vista Using Bluetooth
Step one: Install the software
Install the software so that the appropriate choices can be made during the installation to resolve the issue.
1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
Tips & Tricks: If the software installation does not start automatically, click the Start icon. In the Start Search text box located above the Start icon, type D:\setup.exe, where D is the letter of the CD-ROM drive, and then press Enter.
2. On the User Account Control window, click Continue.
3. Follow the instructions that display on the screen to install the software.
Tips & Tricks: If the User Account Control window displays during the installation, click Continue.
4. When prompted to choose the connection type, select directly to this computer using a USB cable and then click Next.
5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
6. Click Next.
7. Follow the instructions that display on the screen to complete the software installation.
Step two: Install the Bluetooth dongle
1. Insert a Bluetooth dongle in an available Universal Serial Bus (USB) port on the computer. Windows Vista automatically installs the driver for the dongle.
2. If the printer does not have built-in Bluetooth support, insert a second Bluetooth dongle in the Bluetooth dongle port of the printer after the drivers for the first dongle are installed. (If its an HP bt300 or bt450 then the drivers can be Downloaded for the same from hp.com similarly as we download the drivers for the printers)
Tips & Tricks: This step is not necessary for devices that have built-in Bluetooth support.
3. In the System Tray, right-click on the Bluetooth icon and then click Add a Bluetooth Device . The Add Bluetooth Device Wizard opens.
4. Select the My device is set up and ready to be found check box and then click Next .
5. Click the name of the printer.
Tips & Tricks: If the name of the printer is not displayed, verify that the printer is turned on and then click Search Again . After the name of the printer is not displayed, click the name of the printer and then click Next .
6. On the Do you need a passkey to your device? dialog box, select the appropriate check box and then click Next .
7. On the Completing the Add Bluetooth Device Wizard screen, click Finish .
8. On the Found New Hardware window, click Don’t show this message again for this device .
Tips & Tricks: Multiple Found New Hardware windows might display. Click Don’t show this message again for this device each time the window displays.
9. On the User Account Control window, click Continue.
10. Click Finish.
Step three: Update the printer drivers
1. Click the Start icon, right-click Computer, and then click Properties.
2. Click the Device Manager tab.
3. Click the + sign next to other devices to expand the list.
4. Under Other devices, right-click the name of the printer and then click Update Driver Software.
5. Click Browse my computer for driver software.
6. Click let me pick from the list of device drivers on my computer and then click next.
7. Under Common hardware types, click Printers and then click Next .
8. Under Manufacturer, click HP.
9. Under Printers, click the name of the printer and then click Next.
10. On the Update Driver Warning window, click Yes. Windows Vista installs the driver for the selected printer.
11. On the Windows has successfully updated your driver software window, click Close.
12. Verify that the drivers are installed correctly.
a. Click the Start icon.
b. Click Control Panel.
c. Under Hardware and Sound, click Printers.
d. Right-click the name of the printer.
e. Click Properties.
f. Click the General tab.
g. Click Print Test Page.
13. If the test page prints successfully, the printer is installed correctly.
Tips & Tricks: If the test page did not print, verify that the correct printer was selected .
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Install right drivers
I'm Kazi Aslam from Bangladesh. My mobile set is maximus S95 & it is a MTK GPRS Modem. When I connect it through USB port then shows that the necessary software for the INTEX hardware is not found. My questions is what is the software for it & how can I get it?
Dec 08, 2007 | RCA Cable Modem DCM315R (11603540)
Microsoft Windows Vista Ultimate Edition Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
