Question about Canon MF8180C Color Laser MFC Printer
PRINTER SOMETIMES CAN AND SOMETIMES CANNOT
I USE CANON iR2018N PRINTER
  • 1,219 Answers
Pls. be specific what does printer sometimes can and sometimes cannot?
Describe problem in details.
Posted on Jun 15, 2010
Tried to print, but it says please load A4R paper. What do I do?
HI. go to printer properties and verify the paper size selected . I guess you are using LTR paper size.
May 02, 2016 | Canon iR2018N
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
Feb 22, 2015 | Canon iR2018N
How can i reset my canon printer error code 007
Error code is regarding fixing unite.
1 check Teflon sleeve in fixing , if found damaged than replace,
2 check lower pressure roller and end rubber gear if found damage replace it
3 now start copier press buttons in following sequence
Addi. function *
than 28
again *
than on panel its display " COPIER"
touch it, than again touch on "FUNCTION"
Than Touch on "ERR"
than Touch "OK"
than switch off machine and again start.
machine will ready
Sep 26, 2014 | Canon iR2018N
My iR2018N canon xerox machine problem is display show out of toner chenge toner.
If you have already tried a new toner cartridge, try another one. Ensure you are using an approved toner cartridge for your model machine. Your toner supplier should have all the required information to provide you with the correct toner. If multiple toners have been attempted and it still fails to properly acknowledge them, call for service.
Oct 24, 2013 | Canon iR2018N
When powder is wasting on the paper what could be the problem?
The image fixing fuser unit dont work.Check the pressure roller lever and the fusing unit heater lamp and the upper and lower rollers.
May 01, 2013 | Canon iR2018N
Where is the waste toner container in a Canon iR2018N
waste toner conteiner of canon iR2018 is in/within Drum unit
Mar 08, 2013 | Canon iR2018N
Canon ir2018n paper with line
If you only have a line when using the adf, cleaning the small slip glass to the left of the copy board glass
Sep 03, 2012 | Canon iR2018N
My canon ir2018 is detected on my computer as a printer but the documents failed to print
Does the copier reports that you need to change paper size? If yes under printer properties set eg A4 as custom.
Check under printer progress window is it set to use printer offline.
Under cmd type ipconfig and compare subnet and gateway with your copier.
If nothing of this send more specific what didi you try to do.
Jun 29, 2010 | Canon imageRUNNER 2018 Copier
Canon MF8180C Color Laser MFC Printer Logo
79 people viewed this question
old marine
old marine
