Question about Dell A215 Computer Speakers
It worked fine until i moved and i plugged it back in and no sound
  • 849 Answers
Check the port (green) where u plugged it.
Posted on Nov 27, 2008
My tv failed to starts ( I see only vertical stripes and have sound) after a few kicks on the back of the panel it is start normally
You either have a Dry Joint, (Bad solder connection) or a Plug thus has not been seated properly on one of the boards which is quite an easy process to repair. You have to remove the back panel and check ALL connectors on all the PC Boards until, by lightly moving the plug and wiring, you find the loose plug and then just press it in place until tightly seated. If not the problem, look for a bad solder joint on the Boards interconnecting wiring until you find the bad wire and re solder.
Jul 31, 2014 | LG 37LE4500.AEK 37le4500 37 Inch FuHd Led...
I bought Philips auxiliary speakers for my Samsung monitor (used with HP desktop computer) which has no speakers. They worked fine until I moved...upon hooking them up in my new location...I do not have...
Hi, I think you connected it wrong. Make sure it is in the green plug on the back of the PC. If that does not fix it. You may need a new audio card. Good luck.
Aug 03, 2011 | Philips Audio Players & Recorders
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
My printer was working fine until I moved. Once I
check the rating is correct. if the plug has a fuse check that. try a different wall socket
May 09, 2010 | Office Equipment & Supplies
I am having troubles with my Turtle Beachs X1s
You may have kinked your controller cable when you moved all your Xbox stuff. You might as well get a replacement controller cable--Turtle Beach sells them for only $4.95 on their website. I'd recommend the newer white one since that looks to be a lot thicker.
Feb 24, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Headset not working at all mic working until moved wires now not
CHANGE THE SOUND SETTINGS FROM SPEKAER MUTE AND VICE VERSA
Jan 28, 2009 | Audio Players & Recorders
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Dell A215 Computer Speakers Logo
19 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
