Question about Ovens
Replacing oven thermostat GE XL 44 (WGBS23WEA6WW)
Thermostat is defective, got a new one. Just wanted to ask about how much needs to be removed to replace it -- specifically threading the capillary tube into the oven
The range top front tilts up a few inches but can't pull it forward much b/c of gas connections to the burners. Do I need to disconnect the burners and spark ignitors, and set the whole range top aside?
or is there some trick to get it in, perhaps get a friend to help balance the range top while I try to thread it through into the oven cavity?
  • icaneatapeac Nov 27, 2008
    thank you very much for the quick reply, I'll give that a try.
    And you are correct, I don't know how typed a J as a W, but the correct model is
    JGB23WEA6WW
    ah
    JGBS23WEA6WW
    President:
  • 2,651 Answers
I cannot look up the part diag. for the model you provided( no model exests), but for the most part, its a mater of unscrewing the burner heads fromthe maintop to allow yo to lift teh top further back, by lifting without uinscrewing them, you runn the chance of kinking/ loosing the gas fittings leading to them. In which case yooull wind up unscrewing htem anyway to repair the leak. As far as the capillary tube, it shoud push right through te opening in cavity where old one comes out
Posted on Nov 27, 2008
Ge oven will not preheat but broiler and stove top still works
Hello.
When an oven won't bake, it's because the bakeelement is burned out. The bake element is the black, pencil- thick tube at thebottom of the oven. When the oven heats, the element glows red. This elementhas an expected life-span of several years. It may last for only one; it maylast for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem.Otherwise, you need to further troubleshoot the oven's electrical system tolocate the defective wire or component. When the temperature is consistent buttoo high or too low, it could be one of several different things.
First checkto see if the thermostat sensing bulb has come loose from its holder. It couldbe lying on the floor of the oven or resting on the heating element. This wouldcause the oven to not heat correctly. If the thermostat bulb is notdislodged, it's likely that the thermostat or sensor is either mis-calibratedor defective. Electronic ovens with a digitaldisplay use a sensor to monitor oven temperature.
To solve temperature problemsfor these models, you may need to replace the sensor. On some digital-displaymodels, you can calibrate the temperature using the key pad. See youroperator's manual for details. Ovens without a digital displayoften use a mechanical system for controlling temperature. On many of theseunits, you can remove the thermostat knob and adjust the knob itself to moreaccurately represent the actual setting of the thermostat.
If, when you remove the knob,there's a screw on the back of it with a small calibration plate, you canloosen the screw, adjust the plate, then tighten the screw again. If the knobisn't adjustable, and the oven temperature is off by more than 35 to 45degrees, you need to replace the thermostat to solve the problem.
Thanks.
Jul 31, 2011 | Ovens
We have a GE XL 44. The oven won't heat up at
sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
Jul 27, 2011 | GE Ovens
Gas self cleaning 30 range. In bake mode does not heat as hot as before, takes longer to bake items.
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Aug 14, 2009 | Ovens
    The Oven is set to 450 does not get above 280
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
  • Aug 14, 2009 | GE Profile JT912 Electric Single Oven
    XL 44 Gas Range Oven temperature problem
    hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
    Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
    Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
    Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
    25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
    Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
    Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
    Step 3: If necessary, replace the thermostat with a new one of the same type.
    If you need to replace the thermostat, follow these guidlines:
    Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
    Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
    Step 3: Install the new thermostat using a reverse procedure.
    Nov 06, 2008 | Ovens
    Ovens Logo
    1,019 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
