Question about Dell Inspiron 1200 Notebook
Verify memory upgrade in a Inspiron 1200
Need to know how to change the setting on my Inspiron 1200 to match the installed memory upgrade.
  • 3 more comments
  • chetock Nov 27, 2008
    What are the proper settings for the minimum and maximum on the page file for a 1.25G memory?
    Memory is installed correctly. Physical memory is still showing 256 of ram when it should now be showing a total of 1.25G of ram.
  • Anonymous Feb 11, 2009
    i have a pc2100 ram that i installed on my dell inspiron 1200 and it simply won't boot it just stops. and i don't know what the problem is, does anyone know what the problem is or can anyone offer me a little help? I WOULD REALLY APPRECIATE IT.
  • laptop mommy Feb 12, 2009
    I have an Inspiron 1200 which I updated to 1GB. I updated the bios to A07 but the 1GB memory is not recognized. The memory recognized is still 256MB.
    The memory I purchased is PC2700 DDR SDRAM SODIMMS. Specifically I purchased the Kingston KTC-PR266/IG.
    I do not know what to do next. Please help
  • JDTec
    JDTec May 11, 2010
    If the Bios or the OS is not seeing the memory, it will not report it.
    You need to check the memory which you installed. Make sure that it is seated correctly and that it is the correct type for your unit.
  • Dell Master
  • 4,338 Answers
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
    Sergeant:
    Champion:
  • 357 Answers
There are no settings, if the memory is the correct type and it is good, it will be recognised and you will be notified that the memory has changed.
Good Luck.
Posted on Mar 09, 2009
    Novelist:
    Scholar:
  • 85 Answers
Are you referring to bios setting? (There isn't one ...it will either recognize the new ram and tell you how much it sees or it wont) sorry.
Does the laptop recognize your added memory?
When you open system properties what does it say in the general tab?
It will tell you right there how much ram is installed. :)
What setting is it that you want to change since there are a few that come to mind.
As long as paging file is set to "system managed paging file" then you should be ok
with that setting
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
Was given inspiron 5000e laptop- / can it be
Yes, you can upgrade to windows XP but it will require upgrading the memory to the maximum supported memory of 512 MB. It is set up with PC100. I would suggest going with PC133 when you upgrade the memory. Be advised though that the PC100/PC133 memory is expensive new but you can usually shop around and find it used for a cheaper price. The 800MHz processor will support the XP operating system.
Jan 09, 2010 | Computers & Internet
Gateway 500x upgrade ram installation.
hi! there if your addibg a memory card check your memory speed if match to other memory card that are installed already,they should have same speed e.g DDR PC228 or SDR PC333 so check this out before installing.But if you replace the older one upgrading,switch off your computer open cover,there is slot there for your memory card bedide your processor,at both end there a lockway,unlock your memory card and pull it out all if you have several one,then insert on one slot if that is one memory card at 2gb lock it on both end.then swich on your computer check this out on your computer properties if there is change.how to do this left click my computer,click properties.regards
Mar 27, 2009 | Gateway Computers & Internet
Upgrading my Dell Inspiron 8200 laptop
I have a Dell Inspiron 8200 P4 2.4ghz and I install 2gig or ram and it works great ddr pc2700 333mhz for $69/gig at bestbuy. I really notice the difference. I also install a 160 gig HDD.
Mar 17, 2009 | Dell Inspiron 8200 Notebook
Memory upgrade for Inspiron 1200
your new ram is either bad, or incorrect, speed. Try to copy the working ram for the correct type
Feb 15, 2009 | Dell Inspiron 1200 Notebook
Slow speed of prining
try doing upgrades on the printer
Nov 11, 2008 | HP LaserJet P3005n Printer
Dell 700m memory upgrade
No, it's not necessary. Verify the memory is compatible with the computer.
Jun 28, 2008 | Dell Inspiron 700M Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Open Questions:
See all Dell Inspiron 1200 Notebook Questions
Dell Inspiron 1200 Notebook Logo
494 people viewed this question
Alun Cox
