Question about HP LaserJet 1200n Printer
Print problem My hp 1200n had a paper jam and after clearing the jam, the print outs are now slanted and it sounds as if the printer is having a problem picking up the paper.
  • 62 Answers
I believe that you may not have properly released the 2 green levers behiind the printer, they need to be in the up position
Posted on Apr 22, 2007
SOURCE:
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Will not print after pulling forward a jammed paper
make sure the paper didn't tear and a peace got jammed somewhere in there. then reset the printer.
Feb 09, 2009 | HP LaserJet 1200n Printer
Documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054450&lc=en&dlc=en&cc=us&rule=8331&product=303753
if it is a cartridge error try check the following:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&rule=8331&product=303753
Nov 26, 2008 | HP Photosmart 2410 All-In-One InkJet...
Paper jam
here try this guide to clearing Jams supplied by HP
Clearing Paper Jam Guide
I hope this clears your problem :)
Apr 02, 2008 | HP Photosmart C4180 All-In-One InkJet...
Out of paper message
It sounds like the roller in the back, clean it with a soft rag with a little bit of alcohol. I had the same problem and ended up throwing it away and bought a Kodak 5300. Did you try going to HP solutions center? Good luck.
Mar 26, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet 1200n Printer Logo
94 people viewed this question
Clive
Clive
Thomas F. Schneider
