Question about Thomson Lyra PDP2842U MP3 Player
Buttons jammed or not working
Machine worked fine for 18 months. Suddenly, when using, kept jumping from Music to radio and after several minutes of doing this turned itself off. I can now not even turn it on. The Menu button on the side appears to be pressed in slightly, suggesting it may be stuck down (which is why it would keep going onto radio). I have taken off the cover and fiddled with buttons, but no joy. Has anyone else had this problem and resolved it? Can it be repaired? Can I get my music files off it if necessary, even though it will not switch on? Any suggestions gratefully received.
  • Warwick Pipe Aug 16, 2007
    It is amazing what WD-40 can be used for! After taking the machine apart, I noticed the buttons were depressing but then not spring back up. As a last resort a gave a quick (careful) spray of WD-40 on the inner workings of the offending buttons, pressed them in and used a precision screwdriver to prise them up. I repeated this a few times on each button and hey presto ... the machine is now in full working order.
I had this problem when my Lyra PDP2842U was in warranty and it was repaired. Nothing I did would get it to work. If yours is out of warranty then I suspect a official repair is out of the question cost wise and reapiring yourself looks to be a no goer. Selling on ebay as a spares or repair looks to be the only way to go (or buy another with a screen/HDD fault). Or take a look here - seem to quite a few with HDD errors who might want to sell cheap.
Posted on May 18, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Basically I have bought this car off somebody in the family and they showed me the whole car including the sound system, which worked fine. Just slot in my Kenwood KDC -W3037, turn it on and it works....
After the car was sitting a month, did you have to jump the car to start it? If so, jumper cables may have crossed poz and neg at battery! this can blow fuse at radio or fuse box! there is no protection from this and could have burn radio up! hope it is only a fuse! Good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 11, 2017 | Car Audio & Video
Vehicle was parked and not started for 2 months.
Hi, there will be diodes in the generator that are letting the power from the battery drain away through the parked times when not in use. to prove it charge the battery- then disconnect the negative terminal on the battery, connect 24 hours later and see if the battery as kept it charge, if so - fit new alternator, good luck.
Feb 22, 2010 | 2001 Lexus ES 300
2004 Mazda 6 suddenly all radio and CD buttons dead
this just happened to me to. do you know whats wrong.? or how to fix
Oct 12, 2009 | 2004 Mazda 6
Xerox WorkCentre 7232 will not Scan to PC
Your error code usually means: Scanner can not find the specified folder/storage location
-wrong document path
May 21, 2009 | Xerox Office Equipment & Supplies
My singer touch & sew suddenly didn't stop
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
Apr 28, 2009 | Singer 1120 Mechanical Sewing Machine
Suddenly quit working
Looks like the lens of the player is dirty or damaged. Try a lens cleaner CD first.
http://www.buy.com/prod/maxell-cd-340-cd-lens-cleaner-lens-cleaner/q/loc/111/90049765.html
If it doesn't work then you will have to get the lens replaced. Since the Player is still under warranty use while you still can..
Jun 17, 2008 | Mintek MDP-1770 Portable DVD Player
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Alpine CDA-9857 Volume Fluctuations
Please see my solution posted on Mar 13. No other brain waves yet!
Mar 13, 2008 | Alpine CDA-9857 CD Player
have you tried useing a cd/dvd cleaner disc sounds like the laser is dirty
Apr 19, 2007 | kawasaki PVS-10921 Portable DVD Player
Thomson Lyra PDP2842U MP3 Player Logo
26 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
shaun taylor
 Grubhead
Grubhead
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
