Question about Philips TP3281C TV
  • Jim Brown
    Jim Brown Nov 27, 2008
    to likha
    not sure if it is the tuner. the input on the back of the tv where the cable is screwed onto. actually has three inputs for attaching, one on top of another. they all go to the same part.
  • 790 Answers
you mean the tuner?
Posted on Nov 27, 2008
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Do i need digital converter box for my KV-32FS120 Sony Wega made in 2005?
You will need a digital receiver box to have digital on this television.
Feb 01, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
UNIVERSAL REMOTE Needed for TV, Home Theatre System & DVD Player
Try maplin...there are a number of 'ONE FOR ALL' remote controls which will do your tv, radio, sky box, cable what you will have to do is program it with the codes for the particular item. the codes are usually supplied in the user manual with the remote.
Nov 28, 2008 | Televison & Video
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I want to connect HD cable signal to HD projector
not directly unless it says hdtv somewhere or you need a converter box.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
