Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi TV 62525 projection DLP TV
TV green light (timer light) blinks even after reset button is reset.. AND even after unplugged, and or reset button reset. This occured after a power outage...but has happened before (power outage) and just did the unplug routine. THIS time unplug did not work so did the reset, still no use. Checked the 'lamp reseat' process and is good there too. Have had it off for over 24 hours too, still no results.
  • 3 more comments
  • hgachicago Dec 23, 2008
    I have a mitsubishi WD 62525 62" 2004. the green light blinks all the time. I reset the main power, and test the lamp at the store. (abt store illinois)
    they said that fix it may be to expensive around $800.00,better buy a new one. I need some opinions about this. hgachicago@sbcglobal.net
  • Anonymous Dec 29, 2008
    I have the exact same problem.
  • bretb61 Dec 29, 2008
    I replaced my lamp and the green timer light remains on. I have unplugged the tv for days and it still will not stop flashing. Also tried the reset button and no change. I am thinking ballast but not sure.
  • Anonymous Jan 08, 2009
    Very same problem. I called Mitsubishi and they advised that I contact a repair person.
  • Anonymous Feb 01, 2009
    Same problem and it is Super Bowl Sunday!
SOURCE: Mitsubishi Projection TV WD-62525
After buying two lamps (at a cost of $500.00) we had to call the Mitsubishi service man. He came out at a cost of $150.00 (his appearance fee), and told us right away (after taking out the lamp that we had newly installed) that the socket was smushed/smashed. He then went opened the set from the back and tooled around, and unsmushed/unsmashed the socket. We were so happy. On installing a lamp we all must shine a flashlight into the compartment so that we can see what this lamp is going to connect to. Just like a lightbulb, there is a socket on the left inside of the compartment that the lamp must plug into. From our dark vantage point we could not see this, and with the newly manufactured lamps, which are not the same configuration as the old, it is a very tight fit and this connection socket is vital -- or the set will not work. I wish they would have told us this. That lesson taught to us by the Mitsubishi service person cost us an additional $100. Well anyway, we are sharing it with you. Good luck. Maryland
Posted on Feb 01, 2007
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
  • 1153 Answers
SOURCE: FIXXING A MITSUBISHI DLP 65731 HDTV REPLACING THE PROJECTION LAMP COVER
What color is it over and can you see the scratch enough to tell if its under or over the lens. Yes it is 2 parts but fluid lies in between. For more info ctechnicians.com
Posted on Jan 07, 2008
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
SOURCE: mitsubishi WS-55859
Easy to fix this problem, I did 1 mounth ago. 30 min and $20 dollar
Posted on Dec 30, 2008
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
The green light labeled "Timer"
u have a bad control box to repair this unit is better to hire a tv tech , total cost may be $500
Nov 03, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
305 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
