Question about Compaq Evo N610C Notebook
HDD upgrade for compaq evo n610c
I read somewhere that the max HDD for n610c is 60GB.
However i saw an ad for a 160GB:
http://stores.channeladvisor.com/computer-memory-electronics/items/item.aspx?itemid=1896827
Will this be fit my n610c?
  • peaza Dec 02, 2008
    thanks for your reply. i guess the only way to find out if it's okay is to try it.
  • Bob Morris
    Bob Morris May 11, 2010
    According to the Compaq Evo N610c Maintenance and Service Guide, The max size specified by HP is 40GB for this model. This drive is known as an ATA-5 IDE drive. I probably wouldn't recommend going over these specs. The 60GB drive was the max size for the N620c.
    Binary Bob
I have a compaq evo n610c with a 160 gig hardrive and a gig of ram a bluetooth top adapter and installed a wireless card with antennas it works fine and reads the hardrive fine and i get the 158 sumthin sumthin gigs that it alwase turns out to be the fans a going harder thoe thats bout it and the batt dies sooner
Posted on Jan 08, 2009
  • Compaq Master
  • 4,338 Answers
Physically the 160 GB drive will fit. I looked at the manual and it just listed 60 GB. But having worked on many Compaq and HP laptops, I would say that you should not have any problems installing it and it being seen as a 160GB. logically.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
Compaq evo n610c 1gb ram is support for windows 7
Not at all!!
I've installed Windows7 in my n610c (with !gb ram) and my laptop is perfectly working.
Windows 7 is not the 'awful' Vista!!!
The most important things are W7 drivers for this laptop. In order to obtain these drivers, you've to download and install 7zip, then you've to expand in folders the exe files of audio ,video, etc.  drivers of windows xp, and let the system find the suitable drivers..
InstallingXP drivers (exe files) in W7  is not possible!
Also ram may be increased over 1Gb, but you've to install the O.S.
after having upgraded your ram, otherwise graphic card will be not working, even reinstallig its driver!!!
I've just made these operations in two Compaq evo n610c, successfully.
I'd  a problem only for Infrared port, but I've fixed it 'asking' system to find the driver into an external usb HDD full of drivers of various PCs. After a few time , also Infrared port driver was OK.
I've made a backup od windows7 drivers (you may use double driver(free) or Windriver Ghost (not free), in order to backup w7 drivers.
Regards
D.
Apr 18, 2010 | Compaq Evo N610C Notebook
How to install extra ram on compaq evo n610C
There is a small door at the bottom of the laptop.It is upgradeable to 1024 MB.
Jan 30, 2010 | Compaq Evo N610C Notebook
How do you turn it on
I have compaq Evo N610c, which would not start when i press the power button, & when i press the power button or slide reset button the battery led blinks umber 8 times and then green 1 times of the HDD led.what should i do, would you please help me, thank you//
Jan 15, 2010 | Compaq Evo N610C Notebook
HDD Upgrading
mshahzad_nas,
Of cause you can upgrade the hdd to 160GB, the system will detect it, don't worry.
Meanwhile, make sure you have the drivers ready for all the hardware, as new new hdd need to be install with a new windows, and u will need the driver for all the hardware to function properly, like wifi and video.
In case you lost your driver disc, here's the link for you to download
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316666&lang=en&cc=us&prodTypeId=321957&prodSeriesId=316664&taskId=135
Your rate for my solution is much appreciated, thanks.
Jan 09, 2009 | Compaq Evo N610C Notebook
Can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Jul 28, 2008 | Compaq Evo N610C Notebook
Compaq evo n610C adding ram
Hi, the ram is located under a cover to the left of the mouse pad, you need a flat blade screw driver to pop it open.
Jun 26, 2008 | Compaq Evo N610C Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
Upgrade HDD for Compaq N610C
you shoulda known that from the start seagate is compatible with most laptops especially 10 years old or younger
Oct 27, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
677 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
