Question about Microtech JTX V5 15" Flat Panel LCD Monitor
Horizontal setting is Out
I am facing a problem of Horizontal setting. My picture is coming in the centre of the screen. I am not able to Expand the raster to ringht or left. Vertical raster is fine. Facing problem in adjusting the horizontal raster on my monitor. Please help. I have tryied all settings from inside.
  • 9,156 Answers
Once you're ruled out your PC and video card by trying a different monitor, I would suspect the problem is a bad video / signal board inside the monitor. If so, it needs component-level electronic troubleshooting to locate the bad part(s).
Posted on Jan 12, 2007
SOURCE:
How can I remove the rectangular block on the screen
Check for and find your set function set buttons and use the vertical expand to go up and down and the horizontal expand to go wider.
Sep 12, 2014 | Mitsubishi CK-36310 36" TV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
No picture on my tv and it has a horizontal line mid screen
either your vertical driver or output circuit capacitor(s) defective, try this remove rear cover and with something insulated like a straw prod and poke around the circuit board,sometimes theres a cold solder joint, if picture starts to expand on screen its a solder joint
Oct 18, 2009 | Televison & Video
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Microtech JTX V5 15" Flat Panel LCD Monitor Logo
67 people viewed this question
Top Microtech Computers & Internet Experts
William Miller
William Miller
RockTheHood
Are you a Microtech Computer and Internet Expert? Answer questions, earn points and help others
