Question about HP Pavilion dv2000t Notebook
HP DV2000 Beep problem (Video?)
We have a HP DV2000 laptop it has a Long beep and two short beep and no dsplay at all. The web says it has a display card problem, others say it's the memory, I have tested the two 512mb DDR2 PC2 5300 on my second laptop ACER 5580 and they are working....
So it is the Display problem,....now, how do I fix this....help.....
  • 4 more comments
  • ismashkhy Nov 27, 2008
    FDC?....
  • sCHLEPP5 Nov 29, 2008
    We have the same problem with our dv2000. If you find out anything let me know. schlepp5@sbcglobal.net
  • zo2a Dec 02, 2008
    i have the same problem please if anyone know how to fix it let me know my e-mail zo2a@hotmail.com thanx
  • Anonymous Mar 23, 2009
    same thing : 1 long two short beeps.
    seems to be a graphics-adapter failure in the whole product line of the dv2000.
    solution: replace mainboard (which may have the same failure inside)
    more efficient: buy a new note/netbook
  • Anonymous Mar 28, 2009
    Exactly the same problem
  • Anonymous Apr 12, 2009
    I just experienced the same problem today. We're also, very much so, not alone. Check it out:
    http://forums11.itrc.hp.com/service/foru...
    http://nf0g.projectnf0.com/coffeebranlax...
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Nvida was sued over this I guess:
    http://hardware.slashdot.org/article.pl?...
    Wish me luck with HP...
  • 502 Answers
The issue is usually caused by broken solder connections of the GPU chip. There are two ways to fix this problem.You can reflow the GPU (repairs the solder connections) or replace the logic board alltogether. You can try to replace the part yourself, it is available on any auction website. There is a Laptop repair guide that teaches you how to install the part yourself. Google how to reflow a motherboard and you will find ways to re-heat the board to repair the solder connections, chances of success of DIY reflow are around 50%. If you'd rather not install it yourself, you can have a third party laptop repair service do it for you.
Posted on Jul 24, 2010
    Genius:
  • HP Master
  • 1,252 Answers
It might be a FDC error , check it for this also
Posted on Nov 27, 2008
No screen display,give 1 long and 2 short beep
The beep codes indicate you probably have a dry joint on your GPU. A reflow should fix it. if you don't know what a reflow is, it's probably not in your skill set, here is a page with a video to show you how it's done. good luck.
Jan 05, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
What might be the cause of hp pavillion dv2000 not displaying on the screen at start up and giving 3 beeps, 1 long and 2 short, sometimes it boot but doesn't get to the desktop area?
1 long beep followed by two short beeps is usually indicative of a failed/failing display adapter. On something as.... rustic as your dv2000 it can be fixed.... but probably would see better value from just replacing the unit.
Oct 23, 2010 | Computers & Internet
Problem for HP HP Pavilion dv2000 15.4" Notebook Laptop PC The power is OK but I get 1 long beep and 2 short beeps when switching on, the screen remains blank and no activity on the laptop
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion DV 2000 no display one long beep and two short beep
The HP DV2000 series has a high failure rate of systemboards. You maybe can get a repair free but you would need to contact HP directly, if your computer is one of the models listed on the below page, because HP has extended their warranty on certain DV2xxx models;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1842189&lang=en&docname=c01300427#c01300427_dv20
Hope this helps!
Aug 12, 2009 | HP Computers & Internet
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem. If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Jun 27, 2009 | HP Pavilion zd7020US Notebook
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
This must be an Award BIOS.
1 long and 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
I doubt there is anything you can do, other then taking it in for service.
It's most likely the video controller.
You might try connecting an external monitor, but I doubt it will function.
Nov 23, 2008 | Toshiba A75-S125 Satellite Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP 1 long and 2 short beeps
I had the same problem. Turn on your laptop (dv2000) and let it do its thing with the black screen and One long and Two short beeps. Keep the laptop plugged in...Now here is where the "are you kidding me" part kicks in.
Wrap your laptop (while it's on) in a blanket and put it on a bed or a couch (where the laptop won't have room to circulate air beneath it). You must leave it wrapped in the blanket for about 30 minutes minimum, or wait an hour if possible.
Chances are, your laptop will get ver hot and shut itself down at some point before you come back in an hour. When the hour is up, try turning on your laptop again. Ideally, it should work and you now have a working laptop again.
I realize this sounds crazy, but I am typing this quick fix from my dv2000 after doing exactly what i just subscribed. I read it on some other forum when i was on my wife's pc. If this doesn't work the first time, try it one or two more times. This trick has something to do with getting a "broken" (?) connection between the video card and the motherboard soddering back together.
Hope this helps at least one of you. Good luck.
Jul 23, 2008 | Computers & Internet
HP Pavilion dv2000t Notebook Logo
1,966 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
