Question about Home
Indoor jacuzzi bathtub problem
When the unit is turned on it has been spitting out black chunks of grease/slime which fill up the tub and stick to the sides when drained. Does it need cleaning or is the pump/engine malfunctioning?
  • khi21983 Dec 26, 2008
    MY JACUZZI WHIRLPOOL BATH IS DRAINING THE WATER VERY VERY VERY VERY SLOW HOW CAN I GET IT TO UNCLOG OR FIXED WITHOUT CALLING A PLUMBER. ( The stopper is in ythe botton just slightly step or push down on it to hold or let water out)
  • 4 Answers
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Posted on Jan 27, 2009
  • 21 Answers
It sounds like the hoses just have build up inside. If there was a problem with the pump you would have a leak and also those pumps do not have much grease that could get everywhere.
Posted on Dec 01, 2008
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Feb 22, 2013 | Jacuzzi Home
Can not turn jacuzzi on or off
What type of jacuzzi tub are we talking about? indoor bathtub or outdoor hot tub?
Rod
US Parts Center
888-521-6183
Jul 04, 2012 | Jacuzzi Pool & Spa
Need to figure out how to clean out the black stuff that comes out when we turn on the air jets
You need to get some jacuzzi cleaner solution or hot tub jet cleaner solution fill the tub with the solution and follow directions to clean them out needs to be done every couple months IF THIS HELPED PLEASE VOTE FOR ME
Aug 26, 2011 | Whirlpool Aquatic Infinity 1 66X66X25...
Have a whirlpool cadet jacuzzi tub and black slime comes out when I turn pump on? how do I get rid of this? I don't use the tub often.
You have a bacteria problem. You will need a cleaner to run through your system. some names to search for ... system flush, Jet Clean, Jet Fresh
Once you run the cleaner through your tub that will eliminate the sludge you are getting
Jan 30, 2011 | Whirlpool Home
Why does black slimy film come out of my jacuzzi everytime I use it even though I clean it? and now my drain is clogged
black slime come from not using regularly..fill jacuzzi and pour a cup of dishwasher detergent and turn jacuzzi on for a while..
Nov 21, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Black stuff comes out of the jets. why?
The black stuff is probably your dead skin and body filth. Fill up the tub with bleach solution and cycle for 15 minutes, once a month.
Oct 11, 2009 | Jacuzzi Home
Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
May 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
874 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
