Question about Refrigerators
The center divider in our hmg-2170-4 is very hot. the fridge is cool and the freezer is cold, but the center is hot enough to burn you if you are not careful.
    Sergeant:
    Champion:
  • 311 Answers
Your condenser fan motor (down by compressor) is not running. Either bad motor or something has blocked it. Also possible that condenser coils are filthy.
Posted on Nov 28, 2008
Center divider between refrigerator and freezer is hot to the touch
Check the cooling coils under the fridge..most likely need a good vacume ckeaning insufucent cooling/warming due to being clogged...remember your fridge has cooling and heating to control frosting up...coils need cleaning periodily especially if you are a pet owner...good luck.
Feb 22, 2015 | Frigidaire Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
