Question about Dell 17" Monitor
Monitor color changed
Monitor background color went from white to a yellow/green. Also there is no more blue displayed on the screen. Model is a Dell M782p.I have already tried setting it back to the original factory settings as well as the controls on the monitor itself. What is wrong?
  • 8 more comments
  • Anonymous Nov 22, 2007
    My monitor colors are acting up. The whites are like a purpleis. The blues are too bright and you cant see the greens. I need help?
  • SSK007 Mar 09, 2008
    monitor display green not another color is display
  • venusCPE Mar 10, 2008
    screen is all yellow now whats the best solution for this...... its now all color yellow.....
  • usedcars Apr 21, 2008
    monitor turn green &yellow i tried unpluging wires & cables & controls on moniter
  • hlidholm Aug 23, 2008
    background went from white to blueish green
  • saraswathy Aug 26, 2008
    my colors r acting up
  • dpdiddy Aug 28, 2008
    My monitor display is has issues please help
  • Anonymous Oct 05, 2008
    screen has turned to yellow green
  • Anonymous Apr 05, 2009
    white background is now greenish
  • Anonymous Mar 24, 2014
    the monitor connected to pc is changing color (red, green, yellow ...)
  • 9,156 Answers
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
Posted on Jan 12, 2007
  • 3 Answers
Sounds like a bent pin in the male conector or one of the RGB wires is broken internally (inside the cable, from bending at the conector neck or stretching the cable), on the otherhand if it is an lcd panel then maybe it was exposed to too much UV light and degraded the color filters. (like how old pepsi cans turn yellow on the side of the road)
Posted on Nov 29, 2007
The cold cathode lamp iffy!
Posted on Jan 13, 2007
  • 3 Answers
Dell makes cheap crappy parts with child labor in 3rd world countrys anyway. if somthing costs more because it is a diferent brand, it is usually because the quality of the components used is better and less likely to break (like SONY or HP for example) my sugestion... get a new one and dont be cheapo cause you'll get what you pay for in the long run. :^/
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
The color pallet changed to blue, green & yellow, how do I change it back? model f1703
try to reset your monitor. just press the menu button to open on screen display, theres an option that says factory settings, choose that option and choose yes to continue..
Sep 12, 2009 | Computers & Internet
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell 17" Monitor Logo
982 people viewed this question
Clive
Clive
Alun Cox
