Question about Belkin Computers & Internet
We just purchased a new Belkin Router and we can't get on line using it. Can you help us?
  • keslk Nov 27, 2008
    We got the computer on line with the new router. Thanks for the healp
  • Arnaud Gaudin
    Arnaud Gaudin May 11, 2010
    does it appear in the "available wireless networks" from your client computer? if so, does it appear as a protected network?
    Novelist:
    Scholar:
  • 85 Answers
Try this also
1 Make sure your modem is connected to the WAN port on your router
2 unplug the power to the modem and router then plug in the modem first and wait for it to fully initialize (you will see the lights come on one at a time until they are all lit and the activity light is flashing) then plug in the power cord to the router
3 Open network connections and "right click" your local area network connection and select "status" and look to see if there are numbers in both send and receive packets. if you only see numbers in one of them (usually send) then it is a connection problem with the LAN cable and you need to make sure it is plugged in all the way solid at both ends but if you see numbers in both boxes then click on the "properties button" then click on "Internet protocol TCP/IP" and then properties again and verify that it is set to "obtain IP address automatically" and the same for "DNS server address" then click ok to close the properties box and then before closing the status window click on the "support" tab and where it says connection status verify that it does NOT have an IP address that starts with 169.x.x.x because an address of 169. means that your computer was unable to acquire an IP address from your router and has assigned itself a default 169 address. And it should have an address that begins with 192.168.x.x (BELKIN default is usually 192.168.3.x and x=any number between 2 to 250 depending on how many computers you have connected to your router
(The following is assuming you have cable internet or have already configured your router for ds)l
4 if you see an ip address there that begins with 192 then your router is probably working fine but has for some reason not acquired an internet IP address from your modem or ISP and the best way to check that would be to log into your router Config page (check router instructions for default login password) and once you are in the Config page click "status" and if you see all zeros in the box then click "renew ip" and it will attempt to acquire IP from modem and if it fails then try unplugging modem again and plugging it back in and after modem boots up click renew again or click “IP release” then “IP renew” could be different depending on router.
There must be numbers in the router connection status other than 0’s for the internet to work.
Once there is an address in the router status info then you should be able to connect to the internet if all of the above is ok
But since there are so many different things that it could be then please try the above and if you still can not connect t hen let me know and I will add more info (wow I really didn’t intend on typing this much…lol) but better thorough than not
Posted on Nov 27, 2008
  • 146 Answers
Suggest you use this site I'm pretty positive it will help you connect..
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Just scroll down look for router name and model #.
My belkin surf suffers from constant disconnects, i've loaded the latest firmware and made sure all my settings are as what my isp has instructed me, Iv'e also borrowed other routers and found they...
You are correct in hearing that Belkin products are often unreliable. I suggest going with a linksys wrt54g router. Very reliable and a great price as well
Jun 06, 2011 | Belkin Wireless Surf Router (F7D2301)
Has no power
1. Check to see if there is an on/off switch on the router. If there is then turn the router on.
2. If it doesn't have a switch or you've turned it on and nothing happens then you should check your
wall outlet to make sure you have power. You can test it by plugging in a lamp or other small electrical
device.
3. If the outlet is working, check your surge protector (If you are using one.) the same way you checked
the wall outlet.
4. If the surge protector is working, then check the wiring of the router power supply. Look for any
damage like nicks or breaks in the plastic shielding. If it is damaged it will need to be replaced. These
can be purchased at electronics stores like Radio Shack. They may be available at Belkin.
5. If there is no damage you have a few choices to make:
a. Replace the power cable. This may or may not solve your problem but if it doesn't work with a new
power supply then the router itself is defective/broken.
b. Return the router for repair or replacement. If you have a valid warrenty then this is a good choice
otherwise you will have to pay for the repair/replacement.
c. Purchase a new router. If this is an older router, over 2 or 3 years old, it may be a good time to
upgrade.
Nov 22, 2010 | Belkin (F5D5231-4) Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
POOR SIGNAL WITH BELKIN N+ ROUTER
1. open internet explorer type 192.168.2.1 in the address bar
2. at the left column under utilities click on the restore factory default
3. it will ask for login password leave it blank click submit
4. click on the restore default and click ok
5.let the restore complete
6.enable security by clicking on the security on the left hand side
7. remember to use 64bitWEP because some of the windows xp doesnt work with wpa-psk security encryption.
8. change the channel to 1, turn off the qos configuration in the CHANNEL AND SSID PAGE
9.then if its still not working download the firmware form the belkin.com/support
10. most of the belkin products gets resolved if u download the firmware for the routers
Dec 19, 2009 | Belkin (F5D72304F5D7000) Router
My router drops connection when I try to add security
did you try to upgrade teh firmware of the router ? that could be a probable solution . Also try to change the channels in the router. Make it to 6 or 11. Sometimes that could help
Thanks Ranjit
Sep 24, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
The new set was not created
if all you are trying to do is browse the internet, you do not need the setup software.
just use a wired connection between your computer and belkin making sure that the belkin is turned on, then go to the following web page
http://192.168.2.1 (this address I seem to remember is correct)
this should bring up the routers web configuration page you can setup the router perfectly well from within.
Oct 10, 2008 | Belkin (F5D5231-4) Router
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
81 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
