Question about Canon PIXMA iP4000 InkJet Photo Printer
Refuses to print
When trying to print, it refuses saying "error number 300"It's not opening the printer connection, even though everything is properly connected. I've already had that problem before, but by switching off the printer and restarting it, it worked. Now this trick does not do it anymore!
  • Mdmadmiral Apr 05, 2008
    I'm using a iMAC OSX v.10.5.2.  I dragged all the Canon information to the trash.   I went into Apple system preferences, print and fax, and dragged the printer to the trash.  I emptied the trash.  Restarted. Inserted the Pixma CD and used the  "easy install".  Put the usb cable into the back of the computer. It now prints.  I also have a Time Capsule but it will not print from it, cable has to be into computer.  To scan I plug it into the Time Capsule.
    President:
  • 2,961 Answers
Disconnect and switch off printer from pc's usb port. Go to add/remove programmes and uninstall printer software and drivers. Go to printer and faxes folder or go through control panel and ensure the pixma printer is deleted, if not right click and delete. Re-start pc and install drivers from your printers cd rom and re connect printer when prompted and not before (if no prompt when software finishes connect printer). Your pc should then idenitify your printer and auto install drivers. If the same error occurs, it's more than likely a hardware failure, and requires replacing.
Posted on Jan 10, 2007
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
I have the same Error Number 300 with my Canon MX850 - it is connected by ethernet cable to my wireless router. I can scan documents OK, but when I go to print it says that the printer does not...
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Sep 30, 2010 | Canon PIXMA MX850 Multifunction Printer
My HP470 OFFICEJET refuses to print
I did manage to solve the problem in the end.  As it seemed to be a communication problem, I restarted my Mac (as opposed to switching off the printer and on again) and it worked!!
Might need you some time in the future though....
Thanks, S Walsh
May 07, 2009 | HP Officejet H470 InkJet Printer
Refuses to print
Do you solve the problem? Because I have the same probleme and I can't fixed it. Give me a solution if you can. Thank tou!
marcelgiosan@yahoo.com
Feb 12, 2009 | Canon PIXMA MX7600 Multifunction inkjet
ERROR 300
my printer is ofline but every thing is connected to pc
Feb 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cartridge
whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
Canon PIXMA iP4000 InkJet Photo Printer Logo
1,701 people viewed this question
Clive
Clive
old marine
old marine
