Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Replacement of gas tank on a Sears GT3000 riding mower
I ordered a new gas tank for the mower, because there is a crack in the tank now, no leak yet. I haven't been able to work on it due to knee surgery. Would like to find out the easy and fastest way to replace the tank.
  • 163 Answers
If theres no leak yet you can easily patch it with an epoxy puddy, available at your local auto parts store. i've used it myself on gas tanks, radiators, boats and its never failed me yet
Posted on Nov 30, 2008
I have a fuel leak under the rear end
is your tank at the rear, under the seat? if so you may have a cracked or bad fuel line or connection. it could be a crack in the tank itself. wipe off the gas and find where its coming from.
May 05, 2016 | Garden
Why is gas leaking out at bottom of the tank where tube connects to gas tank?
If you have already replaced the clamp and tightened. The tube itself could be cracked. Loosen and bend the tube and inspect closely to see if cracking or split opens up. If it does then replace the tube.
There could also be a crack/hole on or near the bottom tank connection. This can be difficult to locate but holding the hose barb on the bottom with a finger and pouring a little gas into the tank.
The hole/Crack should be easy to find. Vibration will sometimes cause a crack in this location. Typically I suspect the hose.
Today's gasoline is notorious for degrading gas lines due to the additives and ethanol from corn.
Good luck hope this helps
Apr 15, 2016 | Garden
Part # for drive belt craftsman gt 3000
http www searspartsdirect com model part 3000A 0736 1509200 WL000217 00005... Lawn Mower Variable Speed Belt Part Number 754 0280 GUARANTEED FIT from... Belt 715 0 Part Number 754 0370 GUARANTEED FIT from Sears PartsDirect
Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
Jun 25, 2015 | Craftsman Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Murry riding mower: Runs great, but gas drains from than while riding or if standing, there is no evidense of leak only smell of gas.
CHECK THESE;
GAS TANK CAP
GAS PUMP SUCTION HOSE END
ANY CRACKS AROUND GAS TANK
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Aug 08, 2013 | Garden
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Gas leak in sears lawn tarctor model
You will have to remove the seat and then the platform where the seat mounts, this will give you good access to the fuel tank. I know it looks like a daunting job but there are only about 8 or 10 bolts that hold the entire thing on and if you look it over before you start to find all the bolts, you can have it off it 10 or 15 minutes.
You can go here if the link works and see an exploded view of it:
http://www.searspartsdirect.com
Type in your model number then select Chassis and Enclosures
Sep 15, 2009 | Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
1,561 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
