It will idol at low rpm . and when i throttle up engine just idols
SOURCE: lawn mower won't idol at a high enough speed
How old is it? Some newer models have a set idle and can't be adjusted
SOURCE: adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
i found out that i had a broken push rod on intake side. put new rod in and adj valves and runs fine. thanks.
