Question about Onkyo TX-NR801 Receiver
In THX mode, no sound from center channel
The center channel suddenly stopped working in THX mode (it is there, but almost completely inaudible) and is barely audible in other modes. I have swapped speakers and it appears to be a problem with the receiver. I have used the level calibration to raise the level of the center speaker. That helps in other modes, but in THX still pretty much nothing.
Does this sound like a hardware problem?
  • Guillermo Andapia Dec 11, 2008
    I have the same problem dis you find a solution of it
  • 165 Answers
Hello if you already switch your center speaker with other and no sound still even in all modes you right you got a problem inside...do this to be shure you have a problem turn it on discnonnect the center speaker and measure with a voltmeter the center output and if is delivering under a 3 volt ac take it to repair shop it has a shortcircuit,.................saludos
Posted on Nov 27, 2008
Built in GE Microwave/electric oven combo. How to increase the volume on the alarm timer on the microwave? It is now suddenly almost inaudible.
I would check the settings. A glitch may have reset them.
Otherwise, I would unplug the oven for a minute, plug it back in, then reset the clock and try it again.
If you still need help, contact me via microwavecontrol.com with your full model number and detailed symptoms.
Oct 01, 2016 | GE Microwave Ovens
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
My right channel is weak. universally. any effect mode and speaker a and b . Seems slightly stronger when balance knob is at center but is still nearly inaudible . Is it the balance pot or a circuit or a...
I have seen this a lot of time on Yamahas, one of the channels are either a bit or a lot softer than the other, this happens after warrenty and you need to have it repaired.
Oct 08, 2013 | Yamaha Rx-v590 5.1 Channel 265w Natural...
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
No sound from centre speaker on my Bose Lifestyle 8 series 2 system. I've checked leads and speakers by swapping them around. If it is the Acoustimass module which units are compatible?
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
Sep 22, 2009 | Bose Lifestyle 28 System
Onkyo 705 has no center channel when digital input is connected...
try with another digital cable.and confirm that your source assigned to digital signal.
Jul 02, 2008 | Audio Players & Recorders
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Onkyo TX-NR801 Receiver Logo
195 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
