Question about Alpine MRD-M1005 Car Audio Amplifier
Mrd-m1005 amp fans not never turned on?
The cooling fans do not come on at all, is there a menu to set the temp they come on or is there a secret menu i can access,
also what is the shut off temp of this amp, it has gone up to 60 dergrees celcius and not shut down is that to hot?
  • sickd Dec 09, 2008
    thank you heaps for that, i should have checked this earlier cos i cut the cover and installed a 80mm cooling fan lol oh well now they be very cool thank you,
  • 160 Answers
The fanns will come on around 75c they are preset 60 is not that hot for an amp but the cooler you can keep it the better it sounds
Posted on Dec 01, 2008
How hot does the alpine Mrd-m1005 amp get before the fans start cooling it ??
Fixya has no idea , suggest you check with the manufacturer ALPINE
Nov 28, 2017 | Alpine Car Audio & Video
When I hook my JL W7 sub to my alpine mrd m1005 amp the sub is pushed out and stays that way
Hello christensen7,
It sounds like there's DC current on the amp output terminals. Disconnect the sub and test the output with a multimeter. If there's DC there, most likely the amp is shorted internally and needs repair.
Hope this helps.
Aug 17, 2009 | Alpine MRD-M1005 Car Audio Amplifier
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Over heats
Hi the over heat will be a result of the fan not running. Most likely the fan itself is faulty, however could be the control also. (more likely fan). Make sure the fan is not being stopped by dirt etc, if you have a tester you can check and see if there is voltage at the fan (when the amp is hot), if there is, replace or seek someone that can assist.
Best of luck
Jul 11, 2009 | Alpine MRD-M1005 Car Audio Amplifier
Is not playing sound
check your signal going to amp and the setting on the amp it self some of those have a setting that wiil shut amp down
Apr 16, 2009 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
I have a mrd-1005 amp and the cooling fans are not turning on
maby the cooling fans need replacing
or its not hot enough for the fans to cool the AMP down
Jul 19, 2008 | Alpine Car Audio & Video
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Over heating
you trouble shoot the problem by opening unit and force-powering fans to test for overheating during "being used loud for a few minutes". Read the fans' label for proper voltage to apply and proper polarity. I am guessing the fans will run on car battery voltage of 12 volts. Also, attempt to close up the unit to simulate real conditions. There should not be fuses for the fans. If unit is now cooling, then look for faulty thermistor, which turns the fan on during rising temperature. Once thermistor is located, a fast test is to "jumper" its two wires to simulate turn on.
Jun 16, 2007 | Alpine MRV-F345 Car Audio Amplifier
Alpine MRD-M1005 Car Audio Amplifier Logo
211 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
