Question about Whirlpool LER3624JQ Electric Dryer
I am trying to replace my dryer cord and not sure of how to hook it up.
  • 128 Answers
The Replacement cord is pretty much generic - the middle wire is ground - goes to the green lug - the other two are hot are can go to either the black or red terminals - it does not matter.
Posted on Nov 27, 2008
I am trying to replace the power cord to my Maytag Legacy series dryer but I don't know where each connection goes plz someone help me
there are 3 screws to put the wires on,left,middle,right,,make sure that the middle wire goes to the middle screw and it doesnt matter about the other two,hook them up to the other screws
May 29, 2015 | Maytag Dryers
Need another cord to put on dryer as my home does not have the large outlet; only a 3 prong outlet. Can this dryer have a new cord put on?
Yes. Putting on a new cord is simple. There is a plate covering the cord that is on there now. Remove the two or three philips screws holding it on. Get a new cord at an appliance store. Use a nut driver to detach the old cord. Hook up the new cord with the colored prongs in the same places as the old. The green will be the one that is missing. Replace the green screw so it is not lost. Be sure to install the cord protector so the sharp edge does not slice through your new cord. Good luck.
Apr 06, 2011 | Roper REX4634KQ Electric Dryer
I am trying to hook up a 3 prong cord into the dryer but I dont know how you hook up the ground wire.
What voltage does the dryer require? There should be a 'nameplate' somewhere on the machine that has the voltage and Gas requirements. (if it isn't a gas dryer then it'll probably be 240 volt. If it is a gas dryer then a standard 120 volt cord should work). Be sure you are attaching the proper cord... The ground wire should be crimped into a ring terminal connector or a spade terminal connector (can be picked up at any hardware store) and screwed onto any metal surface of the machine(there may be a green screw designated for the ground wire connector)
Mar 06, 2010 | Dryers
My dryer all the sudden is blowing the fuse at the panel. It runs for a short time and then blows the fuse. Sometimes it just keeps running and doesent blow the fuse. It is hooked up properly and has never...
UNPLUG THE CORD then,.,,,maybe the cord hooked to the dryer terminal block and just follow the cord to the unit and take off the axcess panel to power cord hookup is shorting out and needs to be replaced being hooked up properly is why its the first place to look for its
Aug 26, 2009 | AEG Dryers
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Sounds like you did everything correctly however it is possible the wall receptacle may be miswired. The white wire is the neutral, black and red are the line feeds ( hot ) and green is ground. If you are sure the receptacle is wired correctly and that the power cord is wired as you say it is, then there may be an internal issue with the dryer..or some packing material was not removed and is burning off. ( make sure the drum can spin freely and you aren't smelling a belt burning) The red and black are normally on either side of the neutral but you should match the color code on the terminal block on the dryer. Hope that helps...
Regards,
Rick
Jan 03, 2009 | Dryers
Electric cord
What you should get is a new 4 wire cord. It is way less complicated than trying to change out the wall receptacle.
On a 4 wire dryer cord you have White(common) in the middle. Red and Black are hot and go on either side of white. If you really want to make it look good you can put red to red on the terminal and black to black but you don't have to. Some dryers may not have those color hot wires. Green hooks to the chassis with a green screw or any screw connected directly to the frame.
Jul 21, 2008 | Kenmore 62802 Electric Dryer
Whirlpool LER3624JQ Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
