Question about Gateway GT4010 (RBGT4010) PC Desktop
I have no sound for my gateway GT4010
Wel I had a sound on the computer at first and I accidently remove it and now I need it back. I also have a fake antivirus protection by the name of winweb security that I can not get off so please some help me out.
  • 395 Answers
The sound drivers can be downloaded from gateways web site here
http://support.gateway.com/support/drivers/getFile.asp?id=21216&dscr=Windows%20Vista%20Realtek%20High%20Definition%20Audio%20DriverVersion:%206.10.0.5322&uid=215677781
for the fake winweb security try malwarebytes anti spyware www.malwarebytes.org its a free scanner
after you install it click check for updates , after it updates disconnect from the web and do a full scan and remove what it finds. when you reboot it should be fixed
Posted on Nov 27, 2008
Gateway gt4010: Had to format with a generic windows xp cd, not the gateway recovery cd. The computer runs, but cant connect to the internet. It wont even recognize that an internet cable is plugged in....
Hello
Here is a link for your pc with the drivers listed you want the modem drivers.
Im assuming your using another pc to make contact to Fix ya.Download and burn the drivers to a cd or floppy,then install to your gateway.
Hope this helps
Thanks for using fix ya
Feb 06, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 will not start most of the time the fan just runs.
Oopen cpu cabinet and then check wehn u power give to it led on mother bord is flashing or not?
If flasshing then your motherbord get power.
Then reattch all connection to mother bord.
Pull cmos cell for 15 minutes from mother bord also change cmos cell if it has low volt or it is old.
Then also cg\heckl your smps box is working properly.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Windows xp wont allow to login
Very possible depending on the computer as you boot up you will see a message to depress F2 or F8 or F10 or possible the del key to start a system restore. Tap on of these keys as it boots up and you should go into the restore mode....
Aug 01, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway stays 10 min at BIOS splash screen
I would say there a minor corruption in your hard drive. How old is this computer?? May time to reformat it.
May 15, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway
The problem is inside the CPU... Open the case and check the voltage of the battery, a small button cell, it should read as 3V.
Check also the heatsink of your processor it might need dusting.
Now try turning it on...
Get back to me and tell me more about it.... ;)
Dec 11, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
My computer problem
Remove and refit memory sticks, as you mention no beeps, so the memory may need re seating. From there it could be a processor or bios fault not starting up thr first 64KB of memory to boot windows
Apr 17, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 (RBGT4010) PC Desktop Logo
238 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
