Question about JVC HD-56FB97 HDTV
I'm tring to replace my lamp light bulb?
I have a JVC BBE D-ila TV 62', can you tell me exactly where it goes? I have already disassembled the back panel, but I am unsure where to go from here.
  • 1 more comment
  • ystrat06 Nov 27, 2008
    I'm still having a hard time finding it. I have removed the whole back panel and I still do not see it..Can you tell me on which side to look on and where?
    Ok I will try looking and see what I find thank you.
    Thank you so much, I actually found the panel. It is located on the right end panel, it was a big hand held screw that you unscrew with your hand, which is connected to the front left panel. And that panel pops right out. And there is where you will find the lamp unit. I have just replaced my lamp unit. Thanks guys for ALL of your help. I just wasted an hour in the back panel for no reason...lol But thanks to ALL of you, I have located the correct location and replaced it all in 10mins. lol!!
  • JVC Master
  • 5,138 Answers
If you have your owners mannuel book it shows you exactly how to change out Lamp.
Posted on Nov 27, 2008
  • 4,806 Answers
They are not hard to find, they look like 3 light bulbs in a row
regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    the lamp should have a cover
  • Lee Hodgson
    The lamp should be around here
  • Lee Hodgson
    this diagram may also help you
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Volume out on a jvc bbe d-ila tv, what can i do to fix it?
Cannot get sound on JVC BBE D-ILA, what do I do to fix it?
Aug 20, 2011 | JVC HD-61FH96 61" Rear Projection HDTV
Have replaced the bulb in my jvc 61z585 hd-ila rear projection tv. It worked find for two hours. We turned it off for several hours and when we turned it back on we got a picture for ten seconds, then...
Probally the Ballast board have problems,if the safety switch problems,u should not have a picture at all in the first place.Now,the tv turn on?U hearing alot of clicking?Yes,the Ballast board is dead,it not igniting the projection lamp anymore.
Oct 11, 2010 | JVC HD-61Z585 61" Rear Projection...
How do i replace a bulb on a JVC D-ILA tv?
Good Day,
To get the Lamp part number TS-CL11OUAA, around $200.00 cost, 1-800-252-5722/ www.jvc.com.
To replace: The Lamp will come intructions. It is very easy to replace if you have a phillips screw driver.
Good Luck, big IRISH.
Dec 09, 2009 | JVC HD-56FB97 HDTV
Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
Nov 22, 2008 | Televison & Video
Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Dec 27, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Replaced failed lamp but tv still thinks lamp is bad. Tried reset already.
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Feb 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
JVC HD-56FB97 HDTV Logo
417 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
