Question about Logitech HARMONY 659 Remote Control
My harmony is stuck in safe mode
I had the same issue this morning so my apologies for the delay in answering you. After numerous delays and frustrations in being unable to "update" my remote i did the following. First, remove all batteries and disconnect remote from the USB cable. Check ALL buttons to ensure that none are stuck in the down position. I found that my SELECT/OK button was stuck in the "on" position. Continue to check all buttons to make sure all test fine. After doing this hold down the "Off" button while connecting the USB cable, still no batteries in the unit at this time. Hold the "Off" button down for at least 10 seconds or until the units Testing is completed. If the Harmony remote software is up, perform the Update Remote step still sans batteries. After it completes it may perform a self test again (mine did) and after it completes then insert the batteries back into the unit. Hope this helps.
Posted on Dec 26, 2008
Logitech Harmony 520 stuck in safe mode
Use the solution provided at http://www.fixya.com/support/t5148847-not_functioning_message_showing_welcome
Probably a stuck button.
It worked for me.
Jul 05, 2010 | Logitech Harmony 520 LCD Remote Control
Tip
Logitech Harmony Safe Mode Fix Is your Logitech Harmony Remote stuck in SAFE...
Is your Logitech Harmony Remote stuck in SAFE MODE?
If you upgrade / update the firmware of your Logitech Harmony Remote, your remote will no longer be in SAFE MODE.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
Your Logitech Harmony has now had its firmware updated, and is no longer stuck in SAFE MODE.
I hope that helps.
____________________________________________
Logitech Harmony Firmware Update
on Apr 27, 2010 | Televison & Video
Tip
I hope that helps.
Harmony Mac Software Download
Harmony Win Software Download
Harmony Remote Glow Light Fix
What is "Safe Mode?and how do I get this off my remote? It is completely not working. The Activities button is light up and it simply says Harmony Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration. If you are unsure of how to do this, please see below.
- Upgrading/Reapplying the firmware on your Harmony Remote
- http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration (update the remote).
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration (Update your Harmony remote).
May 06, 2010 | Logitech Harmony 520 LCD Remote Control
Remote problems
Hi!
There is actually a link for how to get your Harmony 520 out of Safe Mode:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
Hope this helps you out!!!
-Kennedy
Feb 24, 2010 | Logitech Harmony 520 LCD Remote Control
Logitech Harmony 550 stuck on Safe Mode --Have Changed the batteries and checked that they are in correct--However, unable to access anything with remote including the Help button.
Hi everyone. So I can see that there are a lot of people who are having trouble with their Harmony remotes being stuck in safe mode. Here's how to fix it and get your remote working again:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help
Nov 24, 2009 | Logitech Harmony 550 Remote Control
Harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Aug 29, 2009 | Logitech Harmony 550 Remote Control
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
Safe mode!
I can help you with your Harmony One Remote Control.
Replacing the firmware in your Harmony One is the way to get it out of Safe Mode.
To help you make sure the firmware update is successful:
  1. May I suggest you make sure you are running the latest Harmony Setup Software (V 7.7.0).
  2. Replace your remote's batteries with fresh ones. It is important the remote has sufficient, unvarying power when updating firmware.
I hope that helps.
______________________________________________
Harmony One Manual Download
Apr 18, 2009 | Logitech Harmony One Advanced Universal...
Logitech  HARMONY 659 Remote Control Logo
1,455 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
