Question about Kitchen Ranges
I just purchased a frigidaire stove. We have propane for gas, and the problem I'm having is there is too high of a flame coming out of the stove and the oven. Please help i want to cook something but I'm scared and dont know what to do
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
You need to convert the oven to lp gas, directions to do so are in you owners manual, easy enough /details instructions on how to do!
Posted on Nov 27, 2008
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
Recently purchased a whirlpool gas range from Lowes "return,discounted aisle" I asked had it been converted to propane and they said yes it had. Wife is overly concerned how do you know they can...
Their is no marking or anything easy to determine that.....however natural gas is lower pressure that propane so if you were using propane and it was set to natural ALL the flames would be huge since it would be operating on the higher pressure while it was set for the lower pressure which would result in a flame thrower from each burner and soot so if the flames are pretty normal size despite the small adjustment for the simmer i believe its set to propane.
GENE
Sep 08, 2011 | Whirlpool SF310PEK Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Flame is too high even when on low
The pressure regulator and the orifice for the burners has got to be changed to run LP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 14, 2009 | Whirlpool SF367 Gas Kitchen Range
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Frigidaire Stove
you may have to adjust the flame size so you can simmer.
Nov 05, 2008 | Frigidaire FEF355 Electric Kitchen Range
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frigidaire fgf316wgsh
Is it natural gas or propane? They usually come as natural gas. If it is propane has it ever been converted? If not convert it.
Nov 30, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
131 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
