Question about RCA R52WH73 Projection Television
Sound but no picture after fixing fl231
After replacing the fl231 and resoldering the flyback connections I have sound but no video from any of the inputs. Does anyone have an idea if I just do not have good flyback connections or did I accidently unsolder something that was important in that area? The autoconvergance is available and I can get snow on my analog channles but no picture from any of the outputs.
  • RCA Master
  • 5,138 Answers
Go back over to SSB board the one with tuners on it check fuses next to tuners ,if you have to order ssb board they are 252.00
Posted on Nov 27, 2008
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
No picture but i have sound on my RCA F32676SB 32"
You do an adjustment on the screen nob on the flyback transformer?Resolders the CRT-(tv tube) YOKE wires R,G,B connections to the main PCB board?Resolders the video board CRT-(tv tube)video board pins sockets that connect the video board and the CRT-(tv tube) together.
Feb 13, 2011 | RCA F32676SB 32" TV
Stupid RCA TV....3D picture, 3 colors...replaced FL231 fuse...still didnt fix it...grr...=(
U replaced the one the middle out of the three?Yes,Still the same problems,just replaced all three convergence fuses caps than.Must resolders the FBT- flyback tranformer too.
Nov 19, 2010 | RCA P52926 52" Rear Projection Television
Keeps turing itself off making a hissing sound and turns off, also have a problem with the converange, will not go thur the auto converence picture concave
Resolders the FBT,the flyback transformer.Change the FL231 fuse cap the one in the middle out three near the flyback transformer.
Dec 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
MY HDTV 52IN RCA HAS BOWED PICTURE. I CANT FIGURE HOW TO FIX IT
heres where they are located but you have to resolder the flyback and vertical IC also.
Look at the flyback ( with the Large red wire) Just to the right of the flyback you will see three small brown Fuses the cehter one is FL231 DL231 is just to the right of FL231 and Cl230 is just below and alittle to the right of DL231
Jun 14, 2009 | RCA HD52W59 HDTV Projection Television
The fl231 problem should i fix it or get help
You can fix it but unless you replace DL231, and CL230 plus resolder the flyback and the vertical IC the poroblem will keep returning and blowing FL231
May 02, 2009 | Televison & Video
When i turn on my tv i have a great pic. then after a min or two i get this green and blue and red show behind the words on the sheen how do i get it to go away but if i turn the tv off and back on again...
Is this a shadowing.....like 3d? sounds like your looseing convergence. Now there is a chance your fixing to develop the fl231 problem(fl231 in tips and tricks section) the bad solder connections on the flyback transformer. Also the ribbion connector betweenn the deflection board and ssb my be loose. However i point out that this could be much more... Does the picture also bow inward? my best advice is reseat ribbon connectors and resolder flyback connections... Let me know what happens or if you need some more help
Mar 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red and Green flicker after replacing FL231
Go to the R/G CRT boards at end of neck of picture tubes resolder socket pinns and Video ICs on the board.
Feb 09, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
