Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Fridge gsl25jfpa bs and freezer not getting cold.
We have it in the garage and turned it on to use during the holidays and it is not getting cold. fans are running but compressor is not. We have it connected by an extention cord could this maybe be the problem.
  • 33 Answers
Cord is probably not the problem however try plugging in something that you know works into the cord. the cord should be 12 guage wire. Two things I'd check first. The Cold control may have gotten turned down to where the unit won't kick on. THe second problem is probably the Start relay and/or overload that is found on the compressor may be bad. There is also a capacitor wired in with the Compressor. Your problem is most likely the start relay is bad. If you don't have a meter to test it, the bad relay should rattle like a baby rattle when you shake it. On newer models a door switch could be the culprit....the compressor will not run when the frig door is open, or an electronic circuit board could have gotten zapped and needs replaced.
Posted on Nov 30, 2008
Problem with my GE refrigerator model # GSL25JFPA BS freezer nor frig gets cold but there is still electric to it
check the gaskets on the doors to see if they r sealin proplerly if they r than that means that it is low on freon and it is cheaper to buy another refridgerator.
Aug 23, 2012 | GE GSL25JFPBS Side by Side Refrigerator
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
MY GE GSL25JFPA-BS SIDE BY SIDE REFRIDGERATORS FREEZER TOP PORTION IS NOT COOLING
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | GE GSH25JFR Side by Side Refrigerator
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
GSL25JFPA - Freezer not freezin
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | GE Refrigerators
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Refrigerator and freezer not cold
it could be your cold control stuck turn it on and tap it a few times
Dec 11, 2007 | Frigidaire FRT15G4B Top Freezer...
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
