Question about HP Pavilion dv1000 Notebook
DV1000 KeyBoard Replacement
I used instructions from happi to take the old key board out - worked slick!
When I install the new one how firmly do you press the contacts back into the motherboard?
Mine has orange juice spilled on it - can I soak it in an alchol solution to disolve the sticky stuff anfd get it working?
    Scholar:
  • 162 Answers
You press just enough to hear it click. Light pressure... You will feel the difference when it snaps into place.
Posted on Dec 12, 2008
Last week I had a new motherboard installed on my Asus Q500A laptop. When I got it back the keyboard backlights no longer worked. This wasn't a problem before I sent it out for repair.
Don't get mad. If your mother board was replaced it was probable replaced with one that was system compatible not necessarily one that was OEM(original manufacturers equipment). A keyboard back light strikes me as model specific and not necessarily a standard you would find on a non-OEM replacement part. My guess is, nothing is wrong with your equipment. You just had better equipment than they are replacing it with. I wouldn't be happy if it was repaired by the manufacturer. But it may be as good as it gets at your local computer place or if you bought the parts yourself. I'll give you a tip I use to keep my mother boards crispy, not fried. 1 always run a laptop cooler. 2 never clog the vents by using on a bed or pillow, & 3 buy systems that run AMD chips because they run cooler.
Jun 16, 2015 | ASUS Q500A-BHI5N01 Laptop i5 2.5GHz 6GB...
How to unstick a= key from key board hp dv1000
get a can of compressed air and spray under the key board, if this continues to be a issue replace the keyboard a replacement can be found on ebay for as little as $20
Nov 06, 2013 | HP Pavilion dv1000 Notebook
Laptop keyboard replacement on a hp privilian zv5000
i think the circuit under "G" key is not functioning due to short circuit.
i recommend to bring this to technician for repair or buy a new keyboard since this is cheaper.
Aug 14, 2009 | HP HQRP Replacement Laptop Keyboard for HP...
The keyboard of my hp dv1000 does not work. some
It sounds like your keyboard may have bit the dust !
If you can get to a DOS Prompt or word pad to check, I will explain.
Start with going across all the top key's. If you find one that does not work, go directly below it and see if that key left to right works. If not your connection is corrupt and the keyboard should be replaced. Example: Type Y and U if the U does not work go below to the J and K, if they don't work, 1 or more of the integrated connections are bad and you will more that likely see at-least 8-10 more key's in that region that also don't work.
Keyboard for the DV1000 units can be purchased for $16.00 to $30.00 US. on (ebay)
Replacing the key board is not a bad job, but will require a little time.
Good luck.
John@johnrraycomputer.com
P.S. DV1000 units are fairly old and you got your money's worth out of that one. !
Jun 10, 2009 | HP Pavilion dv1000 Notebook
Screen replacement.taking the old off and installing the new
OK this is sorta ez and hard. Before you start unplug and take out battery. Ok on most laptops on the top part of the keyboard area is space where there are buttons for volume/power/etc. That piece comes off by using a tiny screw driver. Look for a little dip in the plastic it unsnaps there by popping it up. once this is off you remove the keyboard by removing either the 2 or 3 screws that hold it down. Now dont yank the keyboard out since there is data cable you need to pull out. By holding the keyboard in 45 degree you can pull the data plug from its socket. Now you have the keyboard out and from there u can see that there is a cable that runs to your lcd. Unplug it. That was the worst part of the ordeal. Now close your LCD and turn the lappy over and directyl under the lcd hinge under the laptop should be a tiny bolt holding the hinge down. Remove those and then open the laptop up at and try to pull the LCD out if it still dont come out then there are 2 more screws on each hinge u need to remove. Now it should come off. VIola its done now just put back the new one in same fashion. First hinges
May 26, 2009 | HP Pavilion dv1000 Notebook
I need open the Lap for clean the keyboard
You can lift the affected keys off the keyboard to get at the key contacts. Clean with solvent spray cleaner under the rubber contacts.
The keys can be replaced by positioning over the plactic hinges and pressed home until it clicks into place.
If this doesn't work you will need to replace the keyboard.
Keyboard replacements are available on the Internet, I replaced one from Yall Store for approx. $60
Go to www.yallstore.com
May 15, 2009 | HP Pavilion dv1000 Notebook
HP PAvilion DV 1000 Keyboard Problem
Seems like it actually may be a problem with the keyboard. Could be that those particular buttons are faulty. I would try a new keyboard. They seem to be cheap enough these days!!Hope this helps!
Oct 01, 2008 | HP Pavilion dv1000 Notebook
Keyboard or motherboard?
Its your keyboard thats the problem because if it was you mboard or one of the tracks in the circutry is the keyboard connection panel you would have a problem using all the alphabetical keys because they are all connected to the same track.
Jun 29, 2008 | HP Pavilion dv1000 Notebook
DV1000 manual for replacing keyboard
Dear Trent, I am sorry to hear about the keyboard/milk disaster.. :)
Please find all the info that you need about removing the keys or the complete keyboard at the following guides and HP service manual. I Hope you fix this!! :)
The following guide is for the keys.
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides available for the DV1000 but this guide will be more than enough to help you through this one.
The complete process for the keyboard replacement is here (Section 5.9)
http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Apr 02, 2008 | HP Pavilion dv1000 Notebook
Keyboard problem
Its normally a tiresomejob to try and fix a keyboard, try to check if there are ANY stack keys else you need to open the keyboard and clean it.
Feb 27, 2008 | Toshiba Satellite A45-S150 Notebook
HP Pavilion dv1000 Notebook Logo
236 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
