Question about George Foreman GGR88DK Double Knockout Indoor Grill
No HEATING the double knockout indoor is not working at all. the first symptom was that the left part of the double knockout indoor grill stopped heating and then the right part is not working too. Any suggestions.....
  • 752 Answers
SOURCE: burned wire in George Foreman indoor grill
Have you tried Home Depot? They actually have a pretty good wire section (at least mine does..).
Posted on Sep 13, 2007
0 characters
1 Points
you can find it at
Feb 18, 2013 | George Foreman GGR88DK Double Knockout...
We have a George Foreman grill Model GR144. We bought it at the Wal-Mart in Canon City, Co. on 02/28/11. We have only used it four times. The last time we used it on 06/20/11, it cooked the hamburgers...
The grill is not heating because the heating element of the grill is either defective, or there is a disconnection of wires connected to the heating element. Heat coming from the grill can melt the wire if it is close to it. But if problem is not from the wire, then the heating element is defective and needs replacement.
First, have the wires checked to make sure it's not disconnected. Also, check other parts to make sure there are intact.
Get a screw driver, disassemble the grill, check the wires connected to the heating element. If wires are intact, then you need to replace the heating element.
If you cannot perform the above task, then you might be needing the help of a repairman or you can call a family or friend that has the ability to help you out.
I wish you the best of luck.
Aug 01, 2011 | George Foreman GR10AWHT Indoor Grill
I want to buy 3 of them please help me where can i got it
Currently not available online for purchase. I suggest keeping an eye on Ebay, and local closeout stores. I have one almost the same size and I love it; I understand your interest in this item!
May 19, 2011 | George Foreman GGR88DK Double Knockout...
Foreman gv5 grill just stoped working
There is a thermal fuse in series with the heating coils inside. You will have to disassemble it, find the fuse, take it to an electric supply house and get a replacement. Some soldering "may" be necessary.
Mar 21, 2010 | George Foreman GV5 Indoor Grill
Grill buzzing
No, a buzzing noise merely means that something is vibrating from the magnetic field that is created when power flows through the heating elements. As long as nothing is obviously loose, the grill is safe to use.
Jun 11, 2008 | George Foreman G5 Indoor Grill
Wolfgang Puck 781698 Indoor griddle plug
I dropped mine from the top shelf of my pantry and need to buy a new one. The plug was not damaged, so if you need one, you have mine. I can't find parts anywhere. Leave your email address if you still need it, and will respond in a few days.
Dec 22, 2007 | Wolfgang Puck 781698 Indoor Grill
Foreman Grill GR36CB stopped working
Foreman grills have a fuse on the circuit board, have you popped that section open to visually check the fuse? It could be that simple. Fuses do wear down over time, so depending on how much wear and tear you put in, it could just have broken on its own.
Of course, if you replace the fuse and it still goes, you'll need to double-check to see what's shorting it out. The unit may be dead but I wouldn't bet on it.
Nov 08, 2007 | George Foreman GR36CB Indoor Grill
Burned wire in George Foreman indoor grill
Sep 13, 2007 | George Foreman GR30 Indoor Grill
No power or anything - unit is dead
do this test for heating coil: connect a second ac supply cord directly to the coils wires. does it heat? if so, a fix is feasible. the problem is either the thermostat or a blown component on the board. neither are easy
May 28, 2007 | George Foreman GGR88DK Double Knockout...
Grill died
Contact these guys; and they should be able to give you a repair centre list - i think you are right about the board - if you can post again with the board number we can try to source it seperately Hope this helps :)
Sep 28, 2006 | George Foreman GR44BWVT Indoor Grill
George Foreman GGR88DK Double Knockout Indoor Grill Logo
54 people viewed this question
Top George Foreman Electric Grills & Sandwich Makers Experts
tina gallow
Are you a George Foreman Electric Grill and Sandwich Maker Expert? Answer questions, earn points and help others
