Question about D-Link DWL-7700AP AirPremier Wireless AG Outdoor AP/Bridge 802.11a, 802.11g/b (DWL7700AP)
Cannot connect one d-link dwl-7700ap to another d-link dwl-7700ap
I have connected one unit to one PC via RJ-45 (ethernet) using the PoE provided and have done the same with the other unit. However, though they are discovered respectively in each PC, they are unable to 'see' each other.
Sir I have a problem i have this device
DWL-7700AP Brige but i want to secoure my device
becouse if any person want to connet with me
he just search my network and connected
so if there is some solution for that please give me
Posted on Dec 06, 2008
  • D-Link Master
  • 4,338 Answers
You have to add the MAC address from one unit into the other and Vice versa. Set them up in the repeater mode.
The product manual is on this link, under the Support Resources:
http://www.dlink.com/products/?pid=292
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
How do you get the ezbook pc windows embedded CE6.0 to connect to internet via dial up. Have a service, pulgged it up and unable to connect.
Dial up requires a modem instead of a LAN card. It uses an RJ-11 phone plug and not the bigger RJ-45 LAN plug. You also need a dial up internet service provider, and possibly software to make the phone call. There is a Connections setup in Internet Options, under Control Panel if you don't have the software.
So, you are right on track. Just make the call and enter the user name and password to finalize connection.
Dec 07, 2012 | CTX EzBook V92C266 Notebook
I am having Wirless A/G Outdoor AP/Bridge "DWL-7700AP" how to configur with Direct ADSL line 192.168.0.50 d-Link IP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
If still not able to access it then you need to reset it for that press RESET button for 10 seconds it is in back side of router.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
WAN settings are your internet service provider settings if you want to know wireless settings then click on wireless then you can find your wireless settings .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 19, 2010 | D-Link DWL-7700AP AirPremier Wireless AG...
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
Problem to install Intex RJ 45 Lan card in window XP
Hey try to use the cd you got with your motherboard to install netwok/LAN.
Dec 31, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
Conection inalambric
The XBOX 360 can only be connected via an RJ-45 ethernet wire to the router unless you purchase the wireless adapter. The adapter can be bought at any accessory store such as walmart, Target, Gamestop, etc.
Jul 27, 2008 | Microsoft Xbox 360 Console
Networking
Well, I would guess that if you are hooked up now, then you have a wireless router. If this is the case then you should have rj-45 (ethernet) ports on the back of it also for lan hook-up also. Must come with atleast 4 LAN ports, 1 WLAN port (for the incoming internet signal from your cable/dsl modem), so if you use a reg. ethernnet cord, then yes you should be fine hooking your ps3 to your network(via ethernet cable to your wireless router from the ps3).
Hope this helps...
Jul 18, 2008 | Sony Playstation 3 (PS3) Console
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-link dwl 2000AP
Turn on your AP and push reset button for 30 seconds with pen or any small things (little hole between the antena connector and RJ-45 LAN connector).
Set your laptop IP or PC that you will use to set the AP to 192.168.0.55 subnet 255.255.255.0 Then open your web browser, connect your PC Ethernet to AP Ethernet, remove any proxy setting from your browser temporary, and type 192.168.0.50 enter.
Username is: admin password: none (leave it blank).
Apr 12, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
D-Link DWL-7700AP AirPremier Wireless AG Outdoor AP/Bridge 802.11a, 802.11g/b (DWL7700AP) Logo
240 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
