Portable dvd player keeps saying bad disc
I have a polaroid portable dvd player and every time i put in a disc, even new ones it takes a while and makes noises then it comes up "bad disc" what is wrong, and how do i fix it?
  • 4,806 Answers
Try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Posted on Nov 27, 2008
2 Suggested Answers
ejkudelka
  • 1188 Answers
SOURCE: polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Posted on Nov 29, 2009
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
Polaroid portable DVD player error code ''bad disc''
Good luck!!
Nov 29, 2009 | Televison & Video
Polaroid Portable DVD won't work
First try a couple more discs. If it still doesn't work. Take a little bit of alcohol on a qtip and clean off the little clear circle under the lid. Make sure the dics you are using a not scraped and not foreign. If that doesn't work, order a new one and put the old one in the new box and send it back as broken.
Jun 28, 2009 | Polaroid PDV-0701A Portable DVD Player
Shows bad dics all the time
I have finally fixed ya you BAD DISC error message on the Polaroid PDM-0743 ok, listen carefully, first try cleaning the eye lens in the dvd player with a Que Tip with "distilled water" or with "rubbing alcohol" and then let dry, put movie in, turn power on, and it MIGHT WORK? but my guess it will still say BAD DISC, so if that happends it's take apart time you will only need one tool <p><img src="http://img.photobucket.com/albums/v609/goodold56/Tools.jpg"></p> Take out the battery and Flip the unit over where the DVD players LCD SREEN is sitting on your lap you should find alot of black screws just un install the screws on the back <p><img src="http://img.photobucket.com/albums/v609/goodold56/backofplayer.jpg"></p> but wait take this sticker off too. <p><img src="http://img.photobucket.com/albums/v609/goodold56/sideofpalyer.jpg"></p> and after that <p><img src="http://img.photobucket.com/albums/v609/goodold56/laserlensscrew.jpg"></p>
Mar 30, 2009 | Polaroid PDM-0743 Portable DVD Player
"no disc" error message
Did this problem just start? It may be due to the lens no longer reading the disc. Try a lens cleaner. If your lens went south, it usually is paired with a clicking noise or/and the combination of a no disc/disc error message. I would also recommend staying away from Polaroid dvd players and tv's in the future. They have a habit of not making parts available, especially after the warranty.
Feb 28, 2009 | Polaroid PDM-1058 Portable DVD Player
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Polaroid portable dvd
take off top cover and clean laser manually with wet q tip then use dry q tip to absorb excess moisture.
c
Oct 29, 2008 | Polaroid PDV-0700 Portable DVD Player
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Bad disc
What type of disk is you are trying to play?
Aug 28, 2007 | Polaroid PDM-0742 Portable DVD Player
Disc not spinning
It could depend on the type of media you're using. I noticed that certain types of self made dvd's don't play in this player.
Apr 01, 2007 | Polaroid PDV-0823A Portable DVD Player
Televison & Video Logo
813 people viewed this question
Top Televison & Video Experts
Electro Med Services...
