Need to know how light pilot
Goodman furnace PGB024075-1
  • 306 Answers
First step turn the thermostat off. It is very important.
Next find the knob on top of the gas valve you will see writing on it turn it to pilot it could be in the off position so move it to pilot depress the knob where it goes down about one inch. Take a long lighter long match or something like that and hold at the pilot it will be back in the furnace by the front of the burners. Once the pilot lights hold the button for another 30 seconds. Release the knob now the pilot should be on and the next step is why you turned off the thermostat rotate the knob to on position. Go to the t-stat and turn on the heat.
Posted on Nov 27, 2008
Goodman furnace cacf030a2a fan seems to come in but no pilot light... Help??
might need to bleed the gas line at the furnace, if it has not ran in some time the gas gets weak and will not support the flame needed to keep the pilot light lit
Sep 16, 2015 | Goodman Heating & Cooling
Goodman gas heater model GUE080-4 . pilot lighs , but furnace will not . Electronic pilot lights & stays on for about 1 min, than shuts off seems main gas relay not switching on.need manual
Check roll out switches located around burner compartment.
there is a small square button between the wire terminals press firmly down on it to rest switches. If this solves the problem have the furnace cleaned and checked by a professional HVAC technician.
Bob
Jan 06, 2015 | Goodman Heating & Cooling
Why would my Goodman LP furnace CAPF1824B6CA hum, but not kick on?
most furnaces no longer have a pilot, they are all electronic ignition. first thing to come is the inducer motor. if that is what is humming, then either the run capacitor is shot, or theres an issue with the motor itself
Dec 24, 2014 | Goodman Heating & Cooling
Where is the pilot light on a Goodman LP furnace CAPF1824B6CA
I could not find that exact model but I don't think it has a pilot. I think what you have is a faulty igniter.(its a glow plug)
You need to find it-should be on rt side just in front of a burner venturi. Unplug it and check for continuity.
We have a goodman unit that is both a/c and heat model #PGB048125-1 how do I light the pilot?
if you have a newer high efficiency furnace there is no pilot light. They are all electronic ignition
Oct 06, 2014 | Goodman Heating & Cooling
How do you light the furnace of a goodman ez 1625
We have not lit pilot lights ourselves since 1978 when they outlawed standing pilots in Ca for furnaces. We have electronic ignitions of spark oror hot surface ignition, neither of which can be manually lit.
Do you get any fan action if you flip the fan on from auto?if so, you have power and 24v control power too, I would start there.
Oct 31, 2012 | Goodman Heating & Cooling
I have a Goodman forced air heating system in my attic that's only about 3 years old and I believe the pilot light went out last night in a storm. My problem is that I can't locate the pilot in the unit...
Marc, look for where the gas line enters the furnace and remove the panel adjacent to it. That should gibe you access to the pilot light. Also, look for a pilot access door, near where the gas line enters the furnace. The gas line will either be 1/2" flexible copper tubing. 1/2" black iron pine or 1/2" vinyl coated flexible stainless steel. Look for the lighting instructions inside or on the side of the unit.
Hope this helps you solve the problem.
Mar 24, 2011 | Goodman Heating & Cooling
How do I access pilot to turn on heater?
A GMS Goodman furnace does not have a pilot light. It is electronic ignition.
Nov 29, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Pilot light does not stay lit
check that pilot flame is in contact with the thermocouple the small copper cylinder if not properly burning against adjust if flame is good and the therm/coupl is not covered in soot(wipe clean if has build up)thermocouple gone bad replace
Oct 28, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
244 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
