Question about Philips Magnavox Learning Universal Remote
TV won't work with any remote control
Philips Magnavox TV 32" ;model # P3284C101. Turns on/off, can use all the channel and volume button just fine, but won't work at all with any remote controls.. Also, when it is first turned on there is no picture for about 3 seconds, but there is sound. You can hear that it starts on one channel and then changes to another before the picture comes on.
What I'm looking for is a fix so it will work with a remote control. Yes, we tried the one it came with, we tried a universal one and we checked the batteries on all of them.
Any help would be greatly appreciated. Thank you.
  • ShawnaLynne Jan 01, 2009
    Thanks for trying. I know how to program a universal remote control. This TV doesn't work with any remote. We have the original remote control as well as universals... doesn't work with any. Any help would be great! Thanks
  • Philips Master
  • 4,806 Answers
You have to reprogramme the remote, here is the offical site with instuctions and codes for your device:
regards and dont forget to rate us!!!!!
Posted on Nov 27, 2008
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
The tv keeps on changing channels without the remote, then sometimes is turns off when we change the volume...
Hi,all the tack swicth of your front panel tv is defective ,because as you said when you change the volume sometimes is turns off meaning you have coroded swicth that makes your system control IC of your tv malfunction when you touch the button,in this case you may need tv technician to repair it.
hope it may help,
Oct 04, 2009 | Philips Magnavox TS3260C 32" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Philips Magnavox Universal remote and mute control on Toshiba TV
Ha.....flippped a reset-type button on back of TV set...all is now fine....
May 07, 2009 | Philips Universal PH301S Remote Control
How to program both top and bottom chan & vol button for TV use
I found the code by starting the full library search and was lucky to find it again...for my Magnavox the code is 919...this makes both the upper and lower Volume and Channel buttons work for the television, which just makes it more convenient to use. Thanks
Nov 16, 2008 | Philips PM435S Remote Control
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips Magnavox Learning Universal Remote Logo
120 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
