Question about Logitech Cordless MX Duo 967300-0403 Keyboard
Cordless MX DUO charger
I am having trouble with charging my cordless mouse For some reason I have to place the mouse hard into the cradle so it can be charged,Lately the charging light on the mouse does not light up, I cannot open the unit to try push the spring loaded luggs out further to make conntact with the mouse as I am not sure on how to open the unit without breaking it Does any body have the same problem
  • michelemeoli Feb 03, 2009
    My mouse charger worked for a while, but now does not work anymore. No lights flash up when I put the mouse into the base. Help please!
    Michele
Try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
Posted on Sep 11, 2007
Try wiping off the mouse and base contacts with a paper towel. you
don't have to open the base, just clean the contacts...
Posted on May 28, 2008
I have 2 computers both with mx700 mouse and they have worked great for a few years. All of a sudden, both have stopped charging. The green light blinks to say it is charging when in the cradle but within...
I assume you are using usb socket to charge mouse. The voltage on a USB is 5volts , you may have a problem here. It may not be producing the correct voltage. Or you may have a problem with your cradle. I would suggest you see a repair person and get them to look at the USB voltage and the Mouse cradle..
Hope this helps.
Feb 18, 2011 | Logitech MX700 CORDLESS OPTICAL MOUSE...
I have a logitech cordless mouse that does not charge when placed
either ur cradle or ur battery hav been damaged...
try changin it...
Mar 11, 2010 | Computers & Internet
MY MX 700 OPTICAL MOUSE WONT CHARGE I PLACED IT ON THE CHARGER AND THE RED LIGHT JUST FLASHES IT HAS NEW BATTERIES AND A GOOD CONECTION WHAT DO I DO I have an MX Laser (old but outstanding!) that will not...
Hi smeker2003,
I have the same mouse and the same problem, it has been getting worse for some time. The reason they do this is the gold foil you see on the contacts corrodes away and eventually looses the ability to conduct enough electricity to charge the unit.
If yours is in the beginning stages of failing, simply cleaning the contacts and repositioning it slightly in the charging base may get it charging for now but it won't last long. Mine started having minor troubles about 1 1/2 years ago and completely stopped charging about 3 months ago.
Good news is they are standard AA rechargable batteries, so you can do what I do and simply swap the batteries with another device like phone or camera and charge them in the other device or buy a small wall charger and use it for rechaging once the unit completely stops.
As for the other comment, MX Revo and similar MX series do not have a "user serviceable" battery and as such there is no easy access to it, first try the above suggestion to clean contacts then, if it doesn't work and you have the skill to disassemble and saulder together new battery cells feel free to pry it open, it's preasure fitted but I would recommend just buying a new one as the cost barely justifies the time and expense of rebuilding it.
Chris
Jun 02, 2009 | Logitech Cordless Mouse
No disk came with logitech cordless mx duo, where do i get one?
Select the keyboard from this page :
http://www.logitech.com/index.cfm/403/&cl=au,en?prodcrid=403
Click downloads
Select your operating system
Then choosae the 32 bit file and download it
Feb 16, 2009 | Logitech Cordless MX Duo 967300-0403...
Logitech mx lazer cordless rechargable mouse
You are welcome. Just make sure to rate this issue to close it.
Have a nice day.
Jan 09, 2009 | Logitech Cordless Click! Mouse
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
Logitech Cordless MX Duo 967300-0403 Keyboard Logo
183 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
