Question about Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher
The top washer arm on a Frigidaire-Gallery Series falls off
The washer arm is always just popping off. We have made sure that there was nothing touching it, but it still comes off. Water pressure to much? Or could a part be missing? It screws into the top of the washer, has a white retaining ring that the propellor snaps into,
Its driving us nuts. Whats the fix?
  • fast sammy Nov 28, 2008
    the center piece on my washer popped off and i could not figure out how to put it back my washer still works but i was heritant to use it for fear the water my goe everywear. It did not break it just popped when i closed the door too fast and did not see it.i have yhjis number model DW5000Al serial I h 41713751 notor 5.Ga if that will help. thank you can you solve this problem.
  • Anonymous Jan 07, 2009
    I am able to screw the arm back on but it continue to fall a part broken? Water pressure too high?
    Would love to see a solution...
This also happens with my GLD2350RC, except my dishes won't get clean. I believe its because the water does not circulate right inside. Also I have melted spots from where the arm rested on the heat element. I need to get this this back on.......
Posted on Jan 08, 2009
Dishwasher lower spray arm falls off
The arms on a dishwasher spin with water pressure remove your arm and thouroughly clean and flush through , also check for wear on the arm bushes to see if there is excessive wear , the washers may need to be changed. Check the supply hole to the top arm to make sure it is not blocked.
Feb 08, 2013 | Dishwashers
Frigidaire gallery dishwasher top arm fell off
Reva Daniel, I have actually had this happen to my Frigidaire Pro Series d/w. We have put some tall stemware in the upper rack and this was blocking the rotation of the top arm it actually unscrewed the nut that holds it on. So here is how I have fixed it.
1. Locate the 3 pieces (the nut), (the arm) and (the white plastic connecting piece). the white piece is very small it will most likely be on the very bottom of the dishwasher.2. The small white plastic piece sits inside of the nut and protrudes through the nut and snaps into the arm.3. take the 3 assembled pieces and tighten back on to the top of the wash tub. be patient when tightening this ,it is easy to cross thread. That is all there is to it. if some of the parts are damaged go to Be sure you have your model # (its on the inside right side just as you open the door.)
Hope this Helps Joe
Nov 22, 2011 | Frigidaire Dishwashers
Frigidaire Gallery Series # GLTF 2940FS The washer stopped running in mid rinse cycle. When I try to start it a clicking sound occurs.
You will need to check the drain pump and make sure there is nothing obstructing or restricting the flow of water.Once you know that is clear and the problem returns then you might have to change the main control board and possible the door lock.Also make sure to check the motor and all the wiring the motor.
Dec 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire gallery prof series dishwasher- arms dont work
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher Logo
188 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
