Question about Acer Aspire 5050-3242 Notebook
Acer 5050 laptop shuts down after restart.
Well the comoputer was working fine until one day it started fine but after 10 seconds it shut down and will not boot up at all now can any one help me wuth this problem.
  • 3 more comments
  • gjetama Dec 13, 2008
    it wont power up at all, no led lights no noice nothing at all, I belive the power intake is damaged or the motherboard is damaged.
  • dermot doona Feb 22, 2009
    shuts down & restarts but not when i enter the bios
  • lucestrega Mar 03, 2009
    My acer 5050 will go through like it is trying to boot up and I can get into the setup screen but it will not actually boot it goes to blue screen and then restarts and it repeats this cycle until I turn it off manually.
  • Anonymous May 20, 2009
    Endless rebooting. Quick (and I mean quick) blue screen and just shuts down and restarts.
  • Chester Harvards
    Chester Harvards May 11, 2010
    Is there any LED lights on or noisy when you press power button?
I have a Acer Aspire 5050-3371 Notebook. Before, I had a problem with it's battery and plug, so I disassembled it and found my DC input battery plug broken. I replaced the DC converter, and assembled...
Sometimes when the charger connector breaks, it shorts out the charging module on the motherboard, blowing it. It can also blow the external power supply.
If you can find someone else with a similar power supply, try using it. If that doesn't work, you've got bigger issues.
Jun 25, 2011 | Acer Aspire 5050-3371 Notebook
My acer aspire laptop has a blank screen when it is turned on it was working fine and I pressed alt+f10 then it went blank with just a white blinking cursor
Hold down the power button until the computer completely shuts off, wait 10 seconds, power it back on.
What happens?
Nov 21, 2009 | Acer Aspire 5720 Notebook
Laptop battery problem
Try not to install the battery while its on. Power down the laptop then install the battery and power back on the laptop. Hope that helps.
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 5050 keeps looping the acer screen and shuts down
If the hard drive tested out ok (?) then I would burn a copy of memtest (free just google it) boot from it and test the memory. I would suggest though that the issue is the hard drive or possibly motherboard
Jul 16, 2009 | Acer Aspire 5050-3242 Notebook
Can someone tell me how i can reboot back to factory settings please??
Hold down the power button until the machine shuts off, wait 10 seconds, then press the power button again to turn it back on.
Jun 02, 2009 | Acer Aspire 5535-5050 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Laptop auto shuts off - will not come back on
have you checked the power coming fine. If you were working on battery mode it cud be coz of battery issue...
remove the battery & switch on the laptop in power mode.
Dec 03, 2008 | Acer Aspire 5050 Notebook
How can i reboot my acer desktop
try CONTROL+ALT+DEL
select Shut Down
then Turn Off or Restart
*if your computer is malfunctioning or corrupt or frozen.
Theres alway the manual shut down way
HOLD POWER BUTTTON FOR AT LEAST 6 to 10 seconds or until computer shuts down. Then turn on computer and try again.
Sep 13, 2008 | Acer Computers & Internet
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspireā„¢ T180 PC Desktop
Acer Aspire 5050-3242 Notebook Logo
320 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
