Question about Ashton Digital WRUB-2011i (Twin Pack) (wrub-2011i-2) Wireless Adapter
After connecting to the usb, led lights up, then off, windows does not detect it.
After connecting to the usb, led lights up, then off and windows does not detect it. I´m having this problem for a while, and I don´t know what to do. I´ve tried uninstalling all my devices and installing them again, and nothing seems to work. Note that the usb port works fine when I put something else on it.
  • Renato Nascimento Jan 10, 2007
    I´m connecting the device directly to the usb port on my PC, and not to a hub. I will try charging the device up, though.
    Oh, sorry, in case you mean the pc usb hub, Yes it is powered up.
    President:
  • 2,961 Answers
Is the hub you mention, an extension from another usb port only, as the adapter may need to be powered and require a AC/DC powered hub to work.
Posted on Jan 10, 2007
  • andrew pester
    andrew pester Jan 10, 2007
    Apologies, I mis-read your post,have you used the drivers that came with the wireless adapters? and installed the driver first.
    If windows cannot find it try another port.
Led blink once, not detected
Need additional info. Has it always been this way or did it work at one point in time? Have you checked in Device Manager to insure the USB port(s) are in working order?
Mar 09, 2014 | Transcend Electronics - Others
Acer new 320 gb hdd not being recognized by windows 7 ultimate
Hi, There could be some issues with the files format that is on the hard drive. you said that it could be recognized by the Mac mini, and the led. I would suggest you copy the files from it to the mac mini and then try formatting it on the Windows 7 pc. Another option is that there could be a setting on the registry that you need to remove to be able to use the hard drive. - try going to regedit and then look for this string : HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318} : then choose the one for usb and the look for upperfilters and lowerfilters. just rightclick on it and then delete it. After the restart. you should see the hard drive.
Thank you for using Fixya. Your recommendation is highly appreciated for the free support.
Feb 02, 2012 | Computers & Internet
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
Hi, i have a probelm with my logitech quickcam for notebooks pro lens 4.9 mm lately.. the computer doesnt detect the cam although the LED light is on when connected thro the USB port. it was fine...
http://datamagga.com/Technology/dell-xps-m1530-laptop-web-cam-not-working-in-windows-7-64-bit-qweb-cam-in-use-by-another-programq-error.html
The instructions made my web cam work again!
Mar 17, 2011 | Logitech QuickCam Fusion 961403-0403...
My cordless logitech mouse just stopped working??
batteries?
press connect button on transmitter and mouse
verify that the transmitter is firmly plugged in mine falls out because of the usb to ps2 adapter
make sure windows is even detecting it through device manager
does it light up at all you may have to flip the mouse upside down to see a led light
the above is in no particular order
i wish you the best of luck
Dec 04, 2010 | Logitech Cordless Mouse
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Please describe the specifics of your problem below. We'll add your post as a comment to claimbustr's ''LOST COMBINATION - BRINKS SAFE 5054'' problem, and notify you when a new solution is offered.
I have Simpletech Signature Mini USB 500GB drive. All of a sudden, my computer (Windows XP) stopped detecting it. It does not have any external power supply. I tried to connect it to other computers still no success. I can hear the sound of hard disc spinning and red LED light also glows still I can not detect it.blue light lits just a second .
May 20, 2009 | Computers & Internet
Detection problem
check it on other usb ports, also replace the usb cable
Oct 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Printer CLX-216X not detected by windows
Change the USB cable. If not recognised by vista. Check also whether your USB drivers are properly installed.
If Printer is not at fault please take the copy or a test print log report by continuously pressing the Big buttton with LED inside. Before that check all the trays are in proper position and Powered.
Regards
Rafique
Feb 14, 2008 | Samsung CLX-2160N All-In-One Printer
Ashton Digital WRUB-2011i (Twin Pack) (wrub-2011i-2) Wireless Adapter Logo
129 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
