Question about GE Profile 30" Free-Standing 5 Burner Self Clean Gas Range with Warming Drawer, JGB908 Kitchen Range
F2:E3 error code on a KitchenAid Model # KGRT607
After I get this code I hit the cancel button and it will clear but after a while it returnes. The only problem I have with the range is when I use the oven it sometimes shuts off all by itself.
  • Anonymous May 09, 2009
    Our KitchenAid Electric Built-In Oven Model KEB1101D
    does not work and shows the code F2:E3;
    The shop people suggested to turn off power for a minute and check again. But it does same .....Need help
catriver
  • 878 Answers
SOURCE: F2 Error
Traci, F2 is the error code for a overtemp in the oven compartment. It could be two things. The oven temp. sensor or the main board itself. Start with the temperature sensor. It should ohm out at 1080 ohms at room temp. This of course is the least expensive and probably your problem. The temp sensor is the probe that is in the back wall of the oven. It will remove from the front with two screws. There will be a harness that you can disconnect it from when pulling it out. Some one can ohm it out there. The other possibility is welded relay contacts on the main board. Let's hope it's the sensor. Part number WB21T10007. Catriver..post back.
Posted on Feb 13, 2007
fridgetech
  • 473 Answers
SOURCE: model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Posted on Nov 12, 2007
SOURCE: Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Posted on Dec 21, 2007
aborcass
  • 2651 Answers
SOURCE: troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Posted on Feb 23, 2008
  • 415 Answers
SOURCE: KITCHENAID RANGE #YKGST307
can you get me the full model #?
sounds like it's the keypad.
Posted on Sep 13, 2008
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
Getting an error message from the oven, F2:E3
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
FixYourBoard.com
May 08, 2011 | KitchenAid KEMC378 Electric Double Oven
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My oevn will not work and range had the mesaage: F2:E3 and now F2:E1. Can diagnose the problem. Tom Wilson Thomas_Wilson@rush.edu
F2 - E1 Keypad cable unplugged 1. Check keypad connector for firm connection (keypad connects to control board).
.com
Nov 26, 2010 | KitchenAid Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Kitchen Ranges Logo
399 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
