Question about General Filters 1042-LH Humidifier
Maintenance Hi, I had the General Power Humidifier model 1042 installed in my house Built 2000) It was istalled horizontal. I have never known how to maintinne it. What should I do? Is there any manual for regular maintenance? What do I need to make it work? I live in Ottawa, Ontario. Is there any phone number to contact? Thanks
Frequent knocking noise coming from General Aire 1042 LH humidifier
Hello, it depends where the sound is coming from,if it's in the supply water line it could be caused by water hamer or the inlet side of the solenoid valve might be clogged up with sediment. Water hammer is when the solenoid closes under high water pressure and a water hammer arresters should be installed. If the sound is coming directly from the solenoid valve and is more of a chattering sound then there is a loose low voltage wire or the solenoid is going bad. If you disconnect the power to the solenoid and the chattering stops then solenoid must be replaced as it is the cause of the noise.
Mar 17, 2011 | General Filters 1042-LH Humidifier
No water is making it into the humidifier. Loosened the nut of the water supply and there is water going to the unit
Hello, there could be sediment built up at the saddle valve outlet which is preventing water from flowing to the humidifier, If that is clear than the saddle valve must be replaced.
Jan 25, 2011 | General Filters 1042-LH Humidifier
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Jan 16, 2009 | General Filters 1042-LH Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Continuous water draining from my General 1042 Humidifier.....
This type of humidifer is known as a flow through humidifer, when running water flows through it instead of sitting in a pan. The water draining is normal. This type of humidifer will use more water than a pan type but is much healthier due to the fact that you do not get all the build up of the pan type if you ever cleaned one. also change the water panel every year. to change the water panel there will be 2 screws on the bottom pan. Remove them and the panel will come out, buy a replacement at home depot or such store if available, otherwise from a htg company. Replacement is a little tricky to get it to line up so be patient. If you cant remove the bottom panel due to lack of room, it will come out through the top. You will have to loosen and swing the water feed tube out of the way. That is the only maintainace to this humdifier. Also with this humidifier all you have to do is turn the humidistat to off in the summer, you do not have to turn off the water as with float types. Steve
Nov 28, 2008 | General Filters 1042-LH Humidifier
Change filter
http://www.ontimemall.com/How_to_change_990-13_Pad.pdf
Nov 16, 2008 | General Filters 1042-LH Humidifier
General 1042
The 1042 has a valve that operates on 120 VAC. The 1042-LH has a valve that operates on 24V.
Oct 13, 2007 | General Filters 1042-LH Humidifier
General Filters 1042-LH Humidifier Logo
485 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
