Question about Gateway M675 Notebook
No power, won't charge the battery, the note books hot
  • 5 more comments
  • matthew_zook Dec 14, 2008
    I have the same problem
  • jakewaldron Dec 28, 2008
    I just bought this computer and my battery won't charge. I believe it's the AC adapter because I can't even get enough power to run that computer when it's plugged into the wall. Any suggestions?
  • nixdg Feb 02, 2009
    Mine just all of a sudden shut down and now will not turn on at all. With the power cord plugged in the charge light flashes green.
  • Bill Haughee
    Bill Haughee Feb 02, 2009
    I have battery light flashing charge (which is not a documented behavior) - replaced battery and when on unit continually oscillates between ac power (charging) and battery power
  • Anonymous Feb 11, 2009
    I have the same exact problem with this computer and just got off with Sony support and they claim no issue. Wow, my heart goes out everyone who has paid more than $1000 for this unit only to fail This is a documented class action suit on this problem (known issue since 1998)
  • jcbag Feb 12, 2009
    AC Adapter/Charger Good?...DC Jack Good?...Still No Power, No Charge?...With the Battery Out, Power & Battery Lights Blinks Every 7 Seconds?...With Battery In, Battery Light Flashes Every 5-10 Seconds?...And With A Fully Charge Battery In, The Laptop Turns On Just Fine?...If So, You have Just Witnessed 1 of Dell's DEFECTS. It's Best to have it Repaired by a Qualified Tech who knows SMC AND *Are Aware of THIS PROBLEM*. They Will Do What Dell Should Have Done!...Or Get Another Laptop, if you find a USED Board on Ebay, It will SOON DO THE SAME. Make Sure It's A REFURB 1, At Least you know that Problem was TAKEN CARE OF. AND DON'T FORGET TO CONTACT DELL TO REMIND THEM OF THE LAW-SUIT THEY HAD SOME YEARS BACK ON THIS SAME ISSUE.
  • Anonymous Mar 15, 2009
    I think the connector inside the laptop where the power connects is stripped or not making contact and needs to be replaced.
    How do I find that part
  • 17 Answers
In my case (gateway laptop) turned out to be bad ac adaptor (even though I'd tried a Targus univ replacement and repaired the power jack.
Posted on Aug 02, 2009
Hi, this problem is almost in the power IC, before i met the same, so i think it need replace the motherboars.
Just i found the website is selling the sony laptop motherboards, maybe it can help you, good luck.
http://nbhow.en.alibaba.com/
Posted on Mar 08, 2009
Try udating the BIOS But that did not work for me :S
Posted on Feb 11, 2009
Try taking the battery out and just use AC adapter for power. Likely the unit is unable to charge battery due to bad connection inside the computer. I have the same problem and doing this allows me to use my system without the battery.
Posted on Feb 10, 2009
  • 3 Answers
Sounds like a bad motherboard
Posted on Nov 27, 2008
4 Suggested Answers
VinayT
  • 1884 Answers
SOURCE: battery not charging
Either of the two reasons. The battery may be dead (most likely, depending on the age of the laptop) or the charger may be faulty. Both is unlikely as both of them could not have conked out simultaneously.
Posted on Oct 03, 2009
caroldon
  • 17130 Answers
SOURCE: How do I charge the
Initially the battery must be charged fully and then allowed to discharge for about three times.
After this you can charge the PC with the charger connected and work on it while you are on the desk. while using the battery allow it discharge to the lowest level and charge .
You can use the PC with the charger connected while not moving. The battery will charge off in about 2-3 hours. Choose a power plan / power saver plan by clicking the power options on the control panel.
Posted on Apr 14, 2011
cjblackheart
  • 135 Answers
SOURCE: my sensr480 note book battery
Samsung laptops have this program called Battery Life Extender where this would allow you to choose your charging to 100% or 80%. 80% charging as the program says will lessen the ageing of your battery thus extending the overall battery life specially when your using youre laptop connected to AC more often.
I would guess that you might have activated that program if youre only charging at 80%. Have a look at it at youre programs and reply back.
Posted on Aug 07, 2011
Battery not charging on my asur laptop note book R530U
Battery needs replacement if it does not take charge with known good power cord.
Nov 14, 2013 | Electronics - Others
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
I have a Epc note book and it will take a charge just received i
You say the laptop battery not charge or the Epc can not work with the adapter?
First you try to charge a fine battery with your adapter to confirm the adapter is good or not.
Then use the good adapter to charge your battery to confirm the battery is dead or not.
You should change your adapter or battery.
Jan 18, 2010 | ASUS Eee PC 900HD Netbook
Oct 03, 2009 | Computers & Internet
My LG LW60 notebook computer doesn't charge past 30%. How do i force it to fully charge? hw to dismantle the note book, especally to reach to the battery charger ack connection in side the ote book? I...
I would recommend just buying a new battery. Sometimes when the battery gets to old, it stops charging completely. It's not a got idea to take apart your system because you most likely won't be able to put it back together. A new laptop battery typically runs about $125.00. It would be a lot cheaper to just buy it rather then buying a new power supply, which is what you will need to do if you take apart your computer. I know because it's happened to me before.
Jun 18, 2008 | LG X-Note LM50 Notebook
Gateway M675 Notebook Logo
1,095 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
