Question about Canon PowerShot S2 IS Digital Camera
"Change Batteries" message come on even with new alkaline batteries
I have cleaned the terminals in all batteries I have inserted in my S2IS. I have cleaned the battery contacts in the camera with a Q-tip slightly moistened with rubbing alcohal. All to no avail. Sometimes if I turn the camera on and off 20 or 30 times, alternataing the "shoot mode" with the "playback mode," the LCD screen will light up and I can take a picture, but only infrequently. I would agree with previous posts which describe cold weather as the problem, but my camera tells me to replace brand new batteries when everything is room temperature. I used to use rechargable NMH batteries until they too seemed to have an excessively short life. Seems to me like there's short somewhere, or a failed sensor, but I'm not about to mess with it. Many thanks for your help.
  • 2 more comments
  • Ted Welch Jan 24, 2007
    I stilll have the problem with the change battery indicator going on after only a few pictures as described in my earlier posting above.
    Thanks for any advice you might have.
    Grapejuice
  • Pirate 007 Apr 21, 2009
    I just went to Henry's camera store with the same problem. They said that it is the camera that is the problem not the batteries. Apparently "all" digital cameras using AA batteries experience this problem--the camera sucking the life out of the batteries. The problem is that the cost to repair this is about $150- $200. This is ridiculous. I paid $700 for this originally and now the camera is only worth about $350 new and they want me to pay half the price of the camera to have it fixed? These guys are criminals.
  • Anonymous May 01, 2009
    My batteries are always dead whether they're new or not. I've even changed the small internal battery. What's going on?
I ran into the "change batteries" problem once, and I'm pretty sure it happened because I left the camera in my unheated basement and then tried to use it in a warm room. The problem had absolutely NOTHING to do with the actual batteries: I tried multiple good sets, including brand new alkalines. I can think of 3 possible explanations, starting with the least likely: there could be a component or multiple components that are particularly sensitive to temperature. Note that you can take a room temperature camera outside in zero degrees and it will take many minutes, if not hours, for the internal stuff to get really cold. Thermal shifts cause different materials to expand or contract at different rates. It's possible that the change in temperature when going from one environment to another messes with alignment or electrical contacts: when things get back to equilibrium, problem goes away. Most likely: condensation. Something was unhappy internally until the condensation dried up, then the camera was happy again. I only had the problem once, but I don't leave the camera in the basement anymore.
Posted on Feb 20, 2007
Panasonic Lumix DMC-LS75---I have put in new batteries , yet it says " Please replace batteries" as soon as I turn it on and then switches off by itself. I have cleaned the battery terminals; it stil
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Check the contacts of the battery and in the battery compartment of the camera. They all should be clean and shiny. You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close by a camera.
Nov 23, 2014 | Panasonic Cameras
Www vivitar com
Confirm that the battery is charged
Confirm that the battery is inserted facing the correct way
Confirm that the memory card/battery cover is fully closed
Dirty battery terminals reduce battery performance. Try cleaning the terminals with a cotton swab and reinserting the battery a few times.
Check if there is no debris or anything else in the battery compartment that can prevent correct contact between the battery terminals and the connection points in the camera.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months can be very long for NiMH batteries.
Manganese (Zinc-Carbon) batteries should not be used.
Jan 03, 2014 | Cameras
I bought my canon S5IS 2 years ago.For these 2 years it worked fine but now it is showing "Low battery problem" even when the battery is full charged.I also bought new batteries but that also in...
Make sure that the battery terminals in your camera are clean (rub them with a pencil eraser, q-tip or micro fiber cloth). Dirty terminals can cause poor contact with your batteries, therefore, impacting there performance.
Also, if you are using rechargeable batteries, your batteries may simply need replaced. Try testing the camera with a new set of alkaline or NiMH batteries.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
I have a Canon PowerShot S2IS that gives me a black screen and a "change batteries" message even with new batteries. Is there a way to re-set or re-boot the camera?
Try cleaning the battery compartment contacts with a cotton swab "dampened" in rubbing alcohol. Also clean the battery contacts and the charging station the same way. Thanks, Dana
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Even after putting new batteries it gives message"change the batteries"
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new, may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 07, 2008 | Canon Cameras
Canon S2IS " change the batteries" problem
This worked for me after having the persistent "Replace the batteries" problem for about a year straight.
1. Reset the camera, according to the instructions in the manual. (Power on, hold MENU for 5+ seconds, selectOK, wait, turn camera off).
2. Remove the date/time battery for
two minutes (the tiny one in the battery compartment in its own little plastic holder). Replace after 2+ minutes.
3. Important: Insert freshly charged batteries into the camera.
I tried everything short of getting a new camera, and this was the ONLY thing to work for me. Its also simple enough that it takes 3 minutes to do, in case it were to ever happen again while on vacation, etc.
Good luck and I hope this helps.
Eric
Sep 27, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
