Question about Toshiba TN50X81 50" Rear Projection Television
TN50X81 - one convergence IC runs hot...TV powers off after 5min
I bought this set with a convergence issue...I replaced the convergence ICs (used the Sanyo parts, and the uprated 150 ones, too) and the picture came up fine. I could adjust the convergence and all seemed well.
But after running for 5min or so, the TV would shut off. I noticed that 1 of the convergence ICs was running HOTTER than the other. I've rechecked my soldering (looks OK...I'm an EE, so I'm not inexperienced in these kinds of repairs). I also checked the low-ohm resistors to the convergence ICs...all of these measured fine and showed no signs of overheating. I did use fresh thermal grease when fastening down the new convergence ICs, too.
Again, the TV is a 50' rear projection Toshiba TN50X81 made in March 2000.
  • 4 more comments
  • Karl Nitz Nov 27, 2008
    They were STK392-110 - I went up to STK392-150's. I'm wondering if one of the 150's (the one that is running hot) is just bad? I did by extras this time, so I have a spare to swap in instead.
  • Karl Nitz Nov 28, 2008
    So, I replaced that hot-running convergence IC with another...the same thing is happening - it still runs very hot, compared to the other. I don't have a schematic for this TV set, yet, but the PCB is marked V (for vertical?) by the hot-running convergence IC - the H (horizontal?) IC is running much cooler.
    I've left the TV running to see what happens. I do have an oscilloscope and current probe available (in addition to a multimeter) to look deeper into this. Any guidance would be appreciated. I want to get this one running fine so my kids can have a nice-sized TV set in their play room.
    The TV shut-off again after 15minutes or so. Again, the vertical convergence IC is running very hot - you can only barely touch the heat sink. The horizontal convergence IC's heatsink runs warm, but not uncomfortably so.
    I've read else where about a problem with bad solder on the low-voltage regulators on the deflection board of Toshiba rear projection sets. These are the boards at the end of the RGB CRT tubes, right?
  • Karl Nitz Nov 29, 2008
    OK, I'll give all that a go in the morning and will report back on how it goes. Thanks for the help so far!
  • Karl Nitz Dec 01, 2008
    As you recommended, I resoldered all the connections on the convergence PCB. I paid particular attention to the joints if Q782, Q755 & their heatsinks, as well as connector 726B. I reconnected everything and let the TV play for almost 4 hours straight...it never shut off !
    Still, the vertical convergence IC is running MUCH hotter than the horizontal convergence IC. Is this normal? As described before, the V IC heatsink is almost too hot to touch, whereas the H IC heatsink is warm, but bearable.
    Thanks for all your help, ladywinn!
  • Karl Nitz Jan 19, 2009
    The unit powered off again. I'm going to have to go back in and look at the power supply next, I think.
  • Toshiba Master
  • 5,138 Answers
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Posted on Nov 27, 2008
  • 1 more comment
  • ladywinn
    ladywinn Nov 28, 2008
    Let me know how everything turns out or if you need anymore help.
  • ladywinn
    ladywinn Nov 29, 2008
    Solder loose connections on Reulator ICs Q782 and Q755 located on convergence board also clean plug 726b resolder everything on convergence board and all jumper wires. this should correct your problem.
  • ladywinn
    ladywinn Dec 01, 2008
    It very well could be normal for vert ic side to run hotter because of different circuits but just in case ill do some checking , i have see as to where a leaky capacitor can also do the same thing,anyway as long as set plays it must be OK.
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Dec 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Powers on but no picture
convergence ics need replaced suggest going to local tv repair guy and getting it fixed pretty cheap
Jul 01, 2010 | Toshiba TN50X81 50" Rear Projection...
No picture after replacing convergence ICs on TN50x81
You likely have shorted soldering. If you bought a kit from someone go back to their site and ask for help.
Jan 16, 2010 | Toshiba TN50X81 50" Rear Projection...
Tv turned itself off. turn power back on, picture
Your TV is experiencing a convergence issue as indicated by the 3 blinks. The only way to fix this is replacing the convergence ICs. It is not a hard task to replace these ICs. You just need to know how to solder and work on printed circuit boards.
The convergence ICs are mounted on a large heat sink and are marked with codes starting with the letters STK and there are two of them. You need to replace both.
Look for the heat sink with two ICs mounted on it and check the markings.
Once found, cut the IC legs with a small side cutter and unscrew it from the heat sink. Remove the legs left soldered on the board.
Take note of the IC markings for ordering the right part and how it was installed. Don't forget to buy along with the IC a thermal compound.
Check the pico fuses on the same board. Most likely you will find a blown one. These fuses look very much like a resistor, not like the usual transparent fuse, and usually yellow.
Once you have the replacement ICs, put it on the board in the same way as it was installed before. Make sure the screw holes are aligned before soldering the legs into the board.
Put a reasonable amount of thermal grease/compound between the ICs and the heat sink and fix them with the screws.
Double check the board for any splash of solders that might cause a short circuit and damage the board.
Dec 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
Convergence Issue on Toshiba TN50X81 - Service Manual & Parts Source?
Replace the convergence IC's - P/N STK192-110 with part STK192-150 or 180. Then you can go back in and make the detailed convergence settings and get your picture back in alignement. Also check the flame-resistant resistors around the ICs to make sure that none of them have opened up.
Jan 11, 2009 | Toshiba TN50X81 50" Rear Projection...
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba TN50x81 50 Inch TV most of the images seem to have a ghost image behind them
Remove the right speaker grill, there you will see some adjustemt knobs, I never tried it but might be helpfull.
Nov 10, 2007 | Toshiba TN50X81 50" Rear Projection...
Toshiba TN50X81 50" Rear Projection Television Logo
505 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
