Question about Ovens
Thermador Oven Flashing Blue Lights
I read your response to a posting with a similar problem to mine and was hoping you could help. After a power outage, my Thermador dual range (professional series) oven is not working. The small oven and the gas grills work, but the main oven does not turn out. As well, a blue light flashed twice next to "Oven" and then twice next to "Heating" and then the sequence continues in this manner. Do you have any insight into this? Any assistance would be greatly appreciated.
  • 175 Answers
SOURCE: Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Posted on Dec 09, 2006
  • 6 Answers
SOURCE: Main oven not heating.
Hi, Is this your fan oven element that is not getting heating up? If so we have a guide on our site which may be of assistance:
Posted on Mar 01, 2007
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
  • 3463 Answers
SOURCE: Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Posted on Dec 12, 2008
SOURCE: Faulty Daniela oven
Hi Fiona, here is the service department number 1800886010 or the manufacturers number is 0296041226
Hope this helps
Posted on Oct 23, 2009
I need the specific steps for cleaning my thermador thermatronic II oven
First of all, thank you very much for choosing FIXYA today for your technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Here is a direct link to the ONLINE USER'S MANUAL for a similar model of Thermador Electric Double Oven:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 41 of the manual for complete instructions on the AUTOMATIC SELF CLEANING PROCEDURE for Thermador Electric Convection Double Ovens.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
I truly hope that was helpful to you.
Good luck and take care.
Oct 26, 2011 | Thermador SC302T Electric Double Oven
Thermador oven won't heat up
Hello, welcome to FixYa.
I'll start by saying, I just received an email saying you were asking me a direct question...I will tell you what I know based on my experience with Thermador (extensive) and the description of your post. This sounds like a possible hi-limit thermostat tripped scenario.
I don't know if you know where it is or how to check it, or if this is the case with both upper & lower ovens...but they are independent of each other on the SC302T, so if you can reply and elaborate I'll b glad to help in any manner I can. Thank you for choosing FixYa.
Macmarkus :)
Sep 29, 2011 | Thermador SC302T Electric Double Oven
Sorry to read about your problem, I hope this helps you out.
you have a latch switch error code,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador Ovens
Hi i have a scd272t ovens and the bootom oven heating elements are not getting hot but fans and all else works
Hello,Sorry to read about your problem
Their is a 80% chance you heat element is defective. and 10% your control knob is defective or a broken or worn wire.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 24, 2010 | Thermador SC302T Electric Double Oven
Recently installed our thermador double oven model med302es 07and 220 is hot at wall plus the wires going into the unit, but the electronic panel on front never came on. Curious if were missing any extra...
sounds like your 220 is not wired the correct way
i suggest you call a service company.
Dec 23, 2010 | Thermador C302U Electric Double Oven
Self cleaning F5
Sorry you haven't had an answer to your inquiry yet. You may not even require a remedy any longer, but in the event you do I'll post it.
The "F5" in the smw272 wall unit is indicating the on-board watchdog has detected a oven temperature sensor fault/failure. The remedy issued by Thermador's tech support and authorized technicians service manual's is to first replace the oven temperature sensor. If the display should still display after wards, replace the main relay board.
It may be too late to suggest, but you may be best served having an authorized thermador tech look at it.
Hope that helps, better late than never hopefully.
macmarkus :)
Sep 27, 2009 | Thermador SMW272 Electric Double Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Looking for the repair & users manuals for my thermadore wall oven sc301tp
Hello cfrisz,
I am new to the fixya and I saw that you were looking for a manual. I hope that this information can help you find one if you still are looking.
At this web they have a similar users manual or if you type in model (if there is another number on oven) number maybe they'll have it.
or here is the main website (you might have tried it already)
in the contact us section there is a form to fill out and maybe you can get one that way. I'm not sure on response time. Most company's do not mind giving people replacement manuals.
hope this helps
Mar 07, 2009 | Thermador C302U Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
