Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidare dryer belt replacment
I need the instruction on how to replace a broken dryer belt i did get the belt but how does it go on
  • sweetpeanoah Feb 03, 2009
    How do you put the belt on LEQ2152ES0
  • 447 Answers
If your dryer is the one as pictured it is quite a job! I dont feel like writing a bunch of steps that may not even be the right model. Is the pic correct? Ill try to help if it is.
Posted on Nov 27, 2008
Making a squlling noise while drying
have you checked the belt drive? Belt may need adjusting or replacement.
Jul 27, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
Dryer wont spin
It sounds like your dryer drum drive belt may have broken. Top replace the belt follow the instructions below.
PLease go HERE for a video instructional of thewhole job.
Jan 27, 2012 | GE Dryers
How to replace a fuse in frigidare model gleq2152ee0
you will need to remove the lid,the the control panel then the front panel needs be removed then the drum need to come out depending on what fuse you are replacing. to remove the belt take off the small access panel on the rear and take the belt off the pulley.
Feb 24, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Need exploded pic of dryer and instruction on how to replace belt it is broken
Searspartsdirect.com has some excellent exploded view parts diagrams you can refer to. Two other sites you may also try are pcappliancerepair.com and appliancepartspros.com.
For dryer belt routing diagrams, refer to repairclinic.com. Click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section.
If you need further assistance please let me know. I hope this helps you.
Dec 29, 2009 | Dryers
The dryer belt has slipped off, how do I get to the underneath area to put it back on, it isn't broken, it is a frigidare gallery electric dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. You can now replace your belt but I recommend that you go a little farther. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank You
Dec 09, 2009 | Dryers
Belt replacement on a frigidare stacked dryer
Check the below link :-
http://repair2000.com/wpoolbelt.htm
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Jun 01, 2009 | Frigidaire Dryers
My dryer won't turn when on, I took the back off and a belt it broken. I know that part number for the belt. Where can I find step by step instructions to replace the belt?
If you look up the manufacturer, they will give you instructions on how to replace the belt,or yo can download the info via the internet
Dec 11, 2008 | Dryers
Front loader dryer
Sounds like you have a broken belt. I had the same problem and replaced it myself. If you have someone handy at home, there are detailed instructions on the internet (just search) for replacing dryer belts for your model. That's what I did. A new belt costs about $13. If you need to call a service man in to replace, it might cost between $100 - $200.
Oct 27, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
133 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
