Question about HP Digital Projector xb31 Multimedia Projector
Xb31 digital projector
My xb31 digital projector still projects, but is showing a shadow. I took it to a repair person and they said I have a cracked inside lens and she didn't see that this part could be ordered. I really want my projector repaired because I can't afford to buy a new one right now. Does anyone know someone in the metro Atlanta area who may be able to repair my projector?
  • 36 Answers
There are many so called shops. But I highly recommend an authorized or certified shop. Although HP is no longer making projectors, there are still authorized and certified shops in Atlanta. We can not direct you to one at this time. Good luck.
Posted on Jul 10, 2009
I have an HP XB31 Projector with a broken color wheel. Is there someplace to get a new / replacement wheel without having to buy a used or broken projector on e-bay?
You should be able to get the part directly from HP. See Here.
enter your serial number or parts code and viola.
If it's not listed on the site. Call them. They have many parts not available online over the phone.
Jan 25, 2011 | HP Digital Projector xb31 Multimedia...
There a blue shadow next to every person or picture
on the back of your projector there should be a switch that says some thing like normal-service or something similar to that
place the switch in service, and a kind of grid lookig pattern should show on the screen
next look for the adjustment screws for the colors, because it sounds like the blue position has shifted on you,
this may be caused from moving the tv, or from bumping it.
the adjustment screws may be exposed to where you can acces them easily, or it may require you to take off the back of the projector and adjust them that way
go very slow with your adjustments, as a small movement may cause a big change on the screen.
if your projector has a separate lens array then you will have to adjust the lens position.
for that, there should be adjustment screws located on the side and top of the lens, that way you can adjust both horizontal and vertically.
Dec 18, 2010 | Hitachi 57F500 57" Rear Projection...
The right vertical side of the projected picture seems to be slightly shadowed. Is this the lens or for some strange reason is the bulb going out? It only has about 200-300 hours of use on it
if you have the dp6150 (lcd projector), you have a lens or mirror out of alignment, or something obstructing the light from the inside. if you have a dlp projector (not the dp6150), the light tunnel has collapsed and needs to be replaced. you can get the part from an infocus service center (like av solutions in ny), or send it to them for repair. they're really good. www.avsolutionsny.com
Jan 12, 2010 | InFocus Proxima DP6150 Multimedia...
I have an Oley LCD projector which is showing some
try reversing a vaccum cleaner aand blow out the cubweb.... projectors lasers aare sensitive... you might damage the unit permanently...
Jul 19, 2009 | Office Equipment & Supplies
Dark area on screen
sound if u might have what is called a crt burn
Jan 03, 2008 | Samsung HLN4365W 43" Rear Projection...
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
Blue shadow RCA p52771at
hi yeh it does sound right sorry do know anybody arround there... good luck
Feb 22, 2006 | RCA P52771AT 52" Rear Projection...
HP Digital Projector xb31 Multimedia Projector Logo
260 people viewed this question
Ben Johnson
