Question about Hitachi 10", Table Saw with Stand, Powerful 2.6A Motor with Ste
Hitachi Table Saw Quit Working
I was ripping down a 4X4 with my 10" Hitachi table saw when it bogged down then stopped. Upon trying to restart the saw, it seemed to be seized up. There was some smoke coming from inside the casing right before it went down. I thought it was from the hot wood. A few minutes later I tried it again and it starts to turn very slowly then trips the breaker. It also pulls a lot of juice on the circuit (I see the lights dim). As of now it starts to rotate very slowly and makes a humming noise. It does so for approx. 12 revolutions, before it trips the breaker. I tried some WD40 on the wheel, etc. Did I burn it up? If so, should I try to get it repaired or would it be better to purchase a new saw. I only use it at home. HELP!
  • 25 Answers
Sounds like you've got problems with the armature commutator or one of the bearings is bad. Your best bet is to take it out and visit a local motor repair shop to asses the problem. A new motor could be the answer but at some heavy duty expense.
Posted on Nov 27, 2008
  • Carl Blank Nov 27, 2008
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
When i turn on saw it bogs down and dose not take off spining but is not froz
If you are trying to rip wood with the fence it will most likely be that your fence is not true to your blade check the blade to see if it is the same distance on both ends of the blade to the fence. If that is the case you will need to adjust your blade. Check your owners manuel to start that process.
Jan 27, 2014 | Craftsman 10" Table Saw
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
While cutting , i experienced a bind. Before the saw stopped I shut it off. Left overnight, now will not restart. I have pushed the thermal reset button, however it does not seem to engage. I have checked...
Is this a direct drive or belt drive saw? If belt drive, you can remove the belt and try spinning the motor by hand then turn it on. Sometimes they can get stopped in a dead spot. Do not get your hands/fingers in the way when turning it on. You may need all of them someday.
Aug 08, 2010 | Hitachi C10FL 10" Stationary Table Saw...
My husband lost the set up instructions to his Hitachi table saw.
You can download the owners manual for all Hitachi products by going to http://www.hitachipowertools.com and selecting your product. Below is the link for the online pdf format owners manual for the saw in question.
http://www.hitachipowertools.com/product/files/saws/table_saws/C10FR_OM.pdf
Feb 07, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
Moter bogs down on my saw can anyonehelp
Maybe it's under-wired? When you start it up, if the lights dim, and the saw takes 2 or 3 seconds to come up to speed, then your wire is definitely too small and/or too long. 14 gage wire is almost always too light, although a very short 14 gage extension cord plugged into a circuit wired with 12 gage is OK. The cord on the saw itself is probably 14 gage.
Jan 29, 2010 | Craftsman 10" Table Saw
Saw slowed down. Shut off saw and restarted. runs backward.
Sonmethings shorted out inside motor / strip and see if any debris is in there.
It has somehow repolarised from the negative side to pos side!!
Jan 20, 2010 | Bosch 4100 10" Worksite Table Saw
My handle broke off on my hitachi table saw c10ra3 need to replace it . It is for the rip fence to lock in place. most places i look you had to buy the hole assembley i just need a new handle
go to garage sales and try your luck. ive had the same problem with differant brands and had to replace the whole thing. check manufacturers web site or your owners manual and see if its a replacable part with a part#
Apr 22, 2009 | Hitachi C10RA3 10" Table Saw With Stand:...
Hitachi 10", Table Saw with Stand, Powerful 2.6A Motor with Ste Logo
710 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
