Question about GE A730 Digital Camera
What does write protect mean?
In the camera function it wont allow to take pictures and the screen states Write Protect accross screen.
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Posted on Nov 27, 2008
  • msmollyjames
    msmollyjames Nov 03, 2012
    Thank you so much, Rae!!
Write protect on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 07, 2014 | GE T123 Digital Camera
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
How can we remove write protection in sony dscw320 digital camera
I'm going to assume you mean the "protect" function in the camera, rather than the whole-card "lock" function. I don't think there's a single manufacturer that makes this clear. But let me tell you their little secret... whatever you did to protect it - do it again. It's a toggle function! They wouldn't want to put "protect/unprotect" in the menu system instead of just "protect", it might look 'cluttered'. Of course, it might be more useful too. I just dug out my own Sony camera, and it's easy enough to find; be in playback mode on the picture in question, press 'menu' and scroll to the 'protect' function.
Feb 23, 2011 | Sony DSCW320 Digital Camera
When i turn camera on to take picture it comes up with a blue screen and says write protect and wont let me take pictures but i can still use other functions,what does this mean?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 16, 2010 | Cameras
I turn on my camera and it says "memory card is write protected" what does that mean? because it won't let me take any pictures i can view pictures I've already taken but i can't take pictures. How can I...
It means just that, you can't write new files (take pictures) while its in that state.
Take the card out, and check the left hand side of the card. You should see a small notch that can be moved betwee "Write protect" and "Write Enable".
slide it to the "Write Enable" position.
Jul 01, 2010 | Nikon COOLPIX L18 Digital Camera
What does write protect mean in the screen
most camera data cards have a 'write protect' slide switch on the side of them, which if it is in the 'write protect' mode, nothing can modify, or put new files onto it.
Basically what it's telling you is that you can't take pictures with that card until you pop it out and slide the switch to an 'unlock' or 'non-write-protect' position.
Nov 29, 2009 | Olympus FE-190 Digital Camera
Write protect.
go to menu and find whether sttings is kept in protect pictures , set it to default and try again.
Feb 17, 2009 | Vivitar ViviCam 3750 Digital Camera
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
GE A730 Digital Camera Logo
2,407 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
