I turn my tv on and and can hear it but no picture, then it turns off by itself and the red lamp light comes on
    Master:
  • 623 Answers
It is not a good idea for electronic products to be in storage for long periods of time. It is even a more poor idea to purchase used from a rental center; the result is more often than not a very bad experience.
With no picture, but working sound, it is a loss of the high voltage system. This is almost always failure of the high voltage autotransformer called the flyback and/or the HOT (horizontal output transistor) - which work together in producing the horizontal scan of the raster system and the high voltage to prduce the raster upon which the video picture is modulated.
The failure could very well be from HIGH temperature involved with the storage of the tv set.
The repair costs will be over $150 but not more than $300; depending on the exact parts that need replaced.
But: try the hard reset and the vibration/whacking test first to see if the moving business caused failures.
Hard Reset: Unplug for 4 hours, then try again. Do it twice.
Posted on Nov 27, 2008
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
The Red Lamp light is on.
IF YOU HEAR A CLICKING, ELECTRICAL BUZZING. THIS IS NORMALLY THE BALLAST NOT BEING ABLE TO LIGHT UP YOUR LAMP.
Apr 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Problems with my tv
When ever i turn on my Mitsubishi WD52527 TV it comes on, I hear sound but no picture for around 7 seconds, then the red light under lamp comes on, and the sound go away
Oct 16, 2007 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
