Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
Hvr1600 scheduler problem.
I dont know why i cannot get the scheduler software that came with my wintv-hvr 1600 to display completely. when i click on the scheduler to "add program", the scheduler will pop up and i can add program but it appears that part of the page is cut off! not allowing me to save what i have just scheduled. the only way that i can get out of this program is to ctrl-alt-del. has this happened to anyone else???
  • billygsmf Jan 03, 2009
    thanx for the help!!
  • Amanda Shaffer
    Amanda Shaffer Jan 17, 2009
    I am experiencing the same problem. It doesn't seem to have anything to do with screen resolution.
Sorry, the solution does work. It's a font-size issue. Change the DPI settings and it works!
Posted on Jan 17, 2009
Scheduler window is cut off or to big to click on the Save or Cancel buttons? Please double check that your system display DPI settings are not over 96. Open the display properties of your system under control panel. Click on the settings tab and then advance. Look for DPI settings; make sure it's not over ninety-six. If it's over that bring it back to 96 and restart your computer.
Posted on Dec 31, 2008
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WINTV
Hi, you can download the driver for the HVR-1600 from HERE
(53MB FIle)
Step 1 - Extract the Installer
Download the file to a suitable location on your computer, then extract it . Windows has built in support for zip files, if you right click on the file and select 'extract all' a wizard will guide you through extracting the directory.
Step 2 - Remove the previous software version (if necessary)
If you had previously installed the WinTV-PVR-1600 in your PC, browse to the folder you just extracted to (e.g. through My Computer) and locate a file called hcwclear.exe
Run HCWCLEAR.EXE and choose the options Remove All WinTV Drivers and Applications (Total Removal) and Search All .INF Files for Conflicting Hardware.
Note: wait until the black box has disappeared of its own accord before proceeding.
Step 3 - Reboot
Shutdown and reboot your PC.
IMPORTANT! Once rebooted, please do not cancel any 'Found new hardware' wizards. Also ensure that the original driver CD is NOT in the CD drive.
Step 4 - New Driver Installation
After Windows reboots, you will see some New Hardware Found prompts. For each one, please choose the following options:
4A) On the first page, select 'No, not this time' and click Next.
4B) On the next page, select 'Install from a list or specific location (Advanced)' and click Next.
4C) On the next page you will be asked 'Please choose your search and installation options'. Select 'Search for driver in these locations' and then specify the extracted folder (the folder you extracted in step 1).
Note: Specifiy the 'Driver' subdirectory if Windows cannot find the driver file.
Note: You can also click the Browse button and browse for the directlry created in Step 1.
4D) Keep clicking Next for the rest of the steps then Finish to end the Hardware Installation Wizard
Depending on the model WinTV board, you may see several New Hardware Found wizards. Follow the same steps for each.
Step 5 - Run Setup.exe
Run Setup.exe from the extracted folder (from Step 1). You will be presented with a list of things to install, leave all the default settings and click Install.
Once the installation is complete, all drivers will be installed and you should have a WinTV2000 icon on your desktop.
Apr 11, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Problem installing WinTV HVR 1600
It just means that it is not not registered to work with windows by microsoft.
The manufacturer doesnt have to work with Microsoft to make their products work.
If possible you can go ahead with the installation. To be safe set a restore point before doing so, though
Jan 12, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv stuttering when watch channel, but is fine when record it
Further update: Have downloaded SageTV, and it works fine with the Hauppage card. Is definitely a software problem. Have also tried total uninstall, reinstall, with same results. Also downloaded GBPVR, and it also worked with the card.
Jan 03, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
255 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
